It is currently 29. January 2020, 22:31:51 PM
Post new topic  Reply to topic  [ 9 posts ]
Author Message
PostPosted: 09. February 2008, 14:53:43 PM
User avatar
I have moved down to the H beta line to see if I can get a good measure of the O star RV (RV measurement is something quite new for me. I hope to learn more at Heidelberg) I was hoping to compare my result with the graph fig 1 of the Marchenko paper but that seems to be plotted around a mean of zero and I cannot see a reference to the mean RV of the system. Does anyone know this value?
Thanks
Top
PostPosted: 10. February 2008, 16:37:37 PM
User avatar
Hi Robin,
Why do you think the velocity has been corrected by Marchenko? I assume
they quote heliocentric velocities. Do you find significant disagreement?
Quote:
Thanks
Best regards,
Top
PostPosted: 10. February 2008, 18:29:59 PM
User avatar
Hi Otmar,
Quote:
Hi Robin,
If they are absolute heliocentric velocities then it looks like I have to get more practice measuring RV.
If I take my wavelength of 4861.278 A and apply a heliocentric correction of -0.047 A (from VisualSpec) this gives me -0.099 A relative to the rest H beta (4861.33 A) which is -6.1km/s.
If I am reading the graph correctly, at the current phase Marchenko fig 1 gives about +10 km/s for the O star. I had hoped to get closer.
I also measured Deneb on the same night. I will check that against the published figure.
Top
PostPosted: 10. February 2008, 18:40:39 PM
User avatar
Hi Robin,
Unfortunately, Deneb shows also radial velocity variations. You should
observe proper radial velocity standards, if you want to check your
spectrograph. See e.g.
http://obswww.unige.ch/~udry/std/std.html
Quote:
Top
PostPosted: 10. February 2008, 18:44:33 PM
User avatar
I get an RV for Deneb of +0.5km/s compared with the published figure of -4.5kms so it does not seem to be a systematic calibration error. Perhaps my SN is just not high enough.
Top
PostPosted: 10. February 2008, 18:47:09 PM
User avatar
OK Otmar,
Thanks
Top
PostPosted: 14. February 2008, 16:26:15 PM
User avatar
I think I might have found the source of the problem. My neon calibration lines (LHIRES III) are moving 0.5-1 pixel between the start, middle and end of the sets of exposures. (1 pixel = 37km/s) I am not sure if the cause is thermal or mechanical.
Best
Google Deutsch
Ich glaube, ich könnte gefunden haben, die Ursache des Problems. Mein Neon-Kalibrierung Zeilen (LHIRES III) bewegen 0.5-1 Pixel zwischen dem Beginn, Mitte und Ende des Sets von Forderungen. (1 Pixel = 37 km / s) Ich bin mir nicht sicher, ob die Ursache ist, thermische oder mechanische.
Top
PostPosted: 14. February 2008, 17:33:55 PM
User avatar
Hi Robin,
You could make a series of exposures without moving the telescopes. Then
you could see if the problem has a mechanical cause.
best regards,
Top
PostPosted: 14. February 2008, 18:59:18 PM
User avatar
Hello Robin,
such problems i had also with my Lhiress III. There ist a construction problem with the neon lamp in Lhires. The lamp has to be vertical over the slit !!!!!!!
And the flip mechanism has to work reproducible. If there is a hoirzontal shift vertical to the slit of the lamp during flipping, than you get strong mismeasurements in calibration !
Ciao
Top
Who is online
Search for:
Jump to:
