Aktuelle Zeit: 27. Januar 2026, 17:48:07 PM
 Betreff des Beitrags: Vspec und Win7
BeitragVerfasst: 15. Juli 2011, 21:10:22 PM
gibt es Besonderheiten bei der Installation von Vspec unter Win7 ?
Beim Versuch zu starten kommt diese Meldung.
LG
Error.jpg [ 18.85 KiB | 20929 mal betrachtet ]
 Betreff des Beitrags: MCI32.OCX
BeitragVerfasst: 16. Juli 2011, 06:03:05 AM
Hallo Siegfried
Das Problem ist seit Mai bekannt. Die Fehlermeldung kommt, wenn die OCX-Datei nicht
richtig registriert werden konnte. Die 3? möglichen Lösung stehen unten.
CS
Wolfgang
----- Original Message -----
To: staranalyser@yahoogroups.com
Sent: Monday, July 11, 2011 2:26 PM
Subject: Re: R: [staranalyser] MCI32.OCX missing with Visual Spec
Hi there,
> Renato Polloni wrote:
> you tried to run the progam Visual Spec to the operating system in "xp compatible"
> mode ?
thanks for your message. No I didn't try that. The problem was solved by a hint previously
in this group: I had to register (regsrv32) the OCX files manually from a command shell
that runs in Admin mode. That's what I didnt know... I didnt even know how to run the
command shell in Admin mode, now I do.
Cheers, André :)
To: spectro-l@yahoogroups.com
Sent: Saturday, July 09, 2011 3:48 PM
Subject: Re: [spectro-l] Re: [staranalyser] MCI32.OCX missing with Visual Spec
Hi There
> Robin Leadbeater wrote:
> I am afraid I do not have an answer but I am copying it to the spectro_l group where
> there are more users of Visual Spec. Someone there might have an answer
This means that the ocx component is not correctly registered. Usually this is done during
the installation. I recommend to run under admin right if not the case. Otherwise, André
will let me know.
Valerie
Sent: Saturday, July 09, 2011 3:27 PM
Subject: [staranalyser] Re: MCI32.OCX missing with Visual Spec
Hi Andre,
Most people have been able to instal visual spec under win7 without problem but your
problem has been seen before. Below is the thread on spectro_l
If the suggested fix does not work for you I suggest emailing Valerie Desnoux direct
as she has obviously already seen this problem. (Her email address is on her website
> From: valerie.desnoux
> Sent: Tuesday, May 10, 2011 7:22 PM
> Subject: Re: [spectro-l] Lisa guide image
> Hi
> On 10 May 2011 18:06, Dale Mais wrote:
>>I just downloaded vspecc388 to install on my now laptop and I installed it but when
>> I tried to launch it all I get is the following message:
>> Component ‘MCI32.OCX or one of its dependencies not correctly registered:
>> a file is missing or invalid
>> Any thoughts on this.
> Dale, could to hear from you again...Your contribution to Visual Spec at earlier stage
> was key... Regarding this file, somebedy also mentionned that to me in private. The
> person succeeded in registering manually the MCI32.ocx component.
>> I solved my problem. I put MCI32.OCX in C:\Windows\SysWOW64 and registered
>> it .... but I had to run cmd.exe as the administrator for it to register.
> I guees he used regsvr32.exe - Dale, let me know offline if you need help on this task.
> Did you run the installation as admin ?
> Valerie
Sent: Saturday, July 09, 2011 3:40 PM
Robin,
THIS was the golden clue indeed! The secret was to run cmd.exe as administrator
when registering the ocx. So I did this:
* Launch "cmd.exe" in Windows 7, but don't just hit ENTER but CTRL-SHIFT-ENTER.
This will launch the process as the administrator... which makes all the difference.
* In the new console window, register MCI32.ocx as follows. Path might differ on
your system:
regsvr32 "C:\Program Files (x86)\Visual Spec\MCI32.OCX"
* Then try to start Visual Spec. Mine came up with another complaint about TABCTL32.OCX,
so I registered that as well:
regsvr32 "C:\Program Files (x86)\Visual Spec\TABCTL32.OCX"
Now my Visual Spec starts without complaints and I am ready to try it out with my test
pictures of street lights from yesterday.
Thanks to everybody who engaged in this thread!
André :)
Sent: Saturday, July 09, 2011 1:24 PM
Thank you for your messages. Here is my status:
* I am using the installer for Visual Spec 3.8.8 and then extract the new executable of
Visual Spec 3.9.4 from the zip file.
* The library MCI32.ocx is placed in the same directory as the executable when installing
3.8.8
* I downloaded the VB6SP6. When trying to install it told me that it can't because VB6
itself is not installed.
* So I searched on the net for a download of VB6 runtime, found various such as
http://www.softwarepatch.com/windows/vbrun6.html or
http://www.microsoft.com/download/en/co ... x?id=20429
* When trying to install those it tells me that "the application probably has not been in-
stalled correctly because of a compatibility problem" (I am translating this message
from my German Win7 64bit)
* It asks me to confirm and when I try the SP6 again it still says that VB6 runtime is
not there.
* When I try to register the MCI32.ocx manually via regsvr32 it tells me error code
0x8002801c.
* Looking up this code on the internet didn't lead anywhere so far.
However in a nutshell I am assuming that when an application like VisualSpec requires
some 2rd party components it should distribute these components along with its installer,
shouldn't it... even when it is free.
OWEN BRAZELL wrote:
> I should have said I believe this is the link for it
> http://www.microsoft.com/download/en/de ... en&id=7030
> Owen
OWEN BRAZELL wrote:
> mci32.ocx is a visual basic 6 runtime library. I would check if it exists on your system
> and if not try and download the VB 6 runtime files from Microsoft. If you do have it then
> it is probably not registered properly and I would follow the instructions for doing so.
> You can get links by googling it.
> Owen
> From: Robin Leadbeater
> To: staranalyser@yahoogroups.com; spectro-l@yahoogroups.com
> Sent: Saturday, 9 July 2011, 10:45
> Subject: Re: [staranalyser] MCI32.OCX missing with Visual Spec
> Hello André
> Robin
> From: "AndrÃf©"
> Sent: Friday, July 08, 2011 9:47 PM
> Subject: [staranalyser] MCI32.OCX missing with Visual Spec
> Hello,
> I just got my star analyser 100 a few days ago and I am waiting for clear skies for
> first use. I took some shots of street lights for fun with it today and wanted to process
> the result with Visual Spec.
> Is any of you using Visual Spec? I downloaded and installed and got a French error
> message complaining about a missing file MCI32.OCX, both on Windows 7 32bit and
> 64bit computers. Is there someone here who can give me a clue as to what goes wrong?
> Or do you suggest a different software altogether?
> Thanks in advance,
> André :)
 Betreff des Beitrags: Re: Vspec und Win7
BeitragVerfasst: 16. Juli 2011, 16:25:33 PM
Hello Siegfried
LG
It has happened before. Here is the solution posted on spectro_l (In English I am afraid)
Regarding this file, somebedy also mentionned that to me in private. The person succeeded in registering manually the MCI32.ocx component.
"I solved my problem. I put MCI32.OCX in C:\Windows\SysWOW64 and registered it .... but I had to run cmd.exe as the administrator for it to register."
Valerie
BeitragVerfasst: 16. Juli 2011, 17:23:55 PM
dieses Problem habe ich auch , aber ich habe Win XP Virtual machine installiert und jetzt alles sind OK .
Everything is Mathematics !
BeitragVerfasst: 09. Mai 2012, 18:41:48 PM
jetzt wollte ich, solange ich nichts Anderes habe mit Vspec was mit den Wasserlinien machen....Ergebnis...stürtzt andauiernd ab.......keine Ahnung, was ichd a machen könnte :(
wenn ich da auf "ok" drücke, dann verschwindet das gesamte Programm
Sehr sonderbar! Wer weiß was dazu bitte?
tres_mauvais.jpg [ 100.43 KiB | 19916 mal betrachtet ]
BeitragVerfasst: 09. Mai 2012, 20:20:00 PM
das ist leider nicht die einzige Stelle, bei der Vspec in die Knie geht. Dies geschieht regelmäßig dann wenn man die Spektrallinientabelle geüffnet hat. Das Programm ist sehr unstabil und hat mich so oft zur Verzweiflung gebracht, daß ich es nur noch benutze, wenn es gar nicht mehr anders geht.
BeitragVerfasst: 09. Mai 2012, 21:23:36 PM
ich habe dieses problem auch schon gehabt, habe es gelöst in dem ich dem ich es einfach als Administrator geöffnet habe. Ich muß zugeben, von vielen Problemen, die gelöst wurden, sind nur noch einige übriggeblieben... :(
BeitragVerfasst: 09. Mai 2012, 22:36:26 PM
das Programm bringt mich seit über 20 Jahren fast regelmäßig zur Weißglut. Natürlich nehme ich das nur , wenn es mal bequem und schnell gehen soll,aber meistens endet das in schierer Verzweiflung......das Programm ist gut gedacht und wenn das Alles, was es da so gibt wirklich ORDENTLICH funktionieren wuerde , dann wäre das eine feine Sache, ist aber eben nicht so....was ich mich immer wieder frage ist: wie machen das so große Helden wie Robin z.B., der scheint damit Alles zu können und das sieht bei einigen Anderen eben auch so aus..... irgendwas werde ich schon andauernd falsch machen......
Gruß Berthold
BeitragVerfasst: 10. Mai 2012, 08:31:29 AM
Guten Morgen Berthold,
da kann ich Dir vollkommen beipflichten. Zum Teil ist es wirklich nervig, wenn du irgendetwas tust und auf einmal ist das ganze Programm abgestürzt. :evil: Ich kenne jedoch kein Freewareprogramm, dass auch nur annähend dies leistet, was VSpec kann. Ich habe vor 3 Wochen Herrn Desnoux mal eine Mail mit den übrigen Fehlermeldungen geschickt, aber da kam nix mehr zurück.....
BeitragVerfasst: 10. Mai 2012, 10:05:45 AM
Hallo Dominic,
na ja, das hier weiter zu vertiefen, bringt vermutlich nicht all zu viel.....aber....MIDAS ist eben genau auch "Freeware Programm" und kann eben bedeutend MEHR als VSPEC. (z.B. Echellespektren reduzieren:-) )Vor Allem bleibt man bei Schwierigkeiten eben nicht ohne Hilfe.....der Preis dafür ist halt etwas Linux lernen zu müssen und dann halt die eher sonderbar erscheinenden Shellbefehle........aber die Contexte SMS und OPA von Günter Gebhard sind hervorragend dokumentiert, so dass man da viel lernen kann........und dann geht eben dort ziemlich Alles. Geht was nicht, gibt es wie gesagt sehr schnelle Hilfe......
BeitragVerfasst: 10. Mai 2012, 11:25:25 AM
Hallo Dominic!
Berthold hat völlig recht. MIDAS ist für eine solide und umfangreiche Datenreduzierung besser als fast alles andere weil es von Profis entwickelt, getestet und schon viele Jahre erfolgreich angewendet wird. Die Struktur ist für Mausnutzer in der Tat etwas neu. Mir scheint allerdings, dass wir in der FG das Problem LINUX erfolgreich umsegelt haben. Jürgen Neubert hat eine funktionierende virtuelle Maschine erstellt, die die Linuxumgebung komplett emuliert. Die Installation ist ein Kinderspiel. Und wenn es mal Probleme gibt, steht er mit Rat zur Seite. Auf der FG-Seite findest Du unter den Hauptlinks "MIDAS mit VMware".
BeitragVerfasst: 10. Mai 2012, 12:05:39 PM
MIDAS sieht super aber erstens soll ich Linux lernen :roll:
Für Wasserlinnien gibt es ein MEnu im ISIS auch.
ISIS versteht besser FITS die durch IRIS gespeichert sind.
BeitragVerfasst: 10. Mai 2012, 12:17:32 PM
Na ja Alexandros.....soweit ich das erkennen kann wirst Du als einer , der Mathematik und vielleicht später mal noch Astronomie machen will nur schwer um Linux drum rum kommen....:-)
Von meinem iPad gesendet
Am 10.05.2012 um 12:05 schrieb Alexandros Filothodoros <fg-spek-data@vdsastro.de (fg-spek-data@vdsastro.de)>:
MIDAS sieht super aber erstens soll ich Linux lernen Bild
BeitragVerfasst: 10. Mai 2012, 14:34:05 PM
[quote="Berthold Stober"]Na ja Alexandros.....soweit ich das erkennen kann wirst Du als einer , der Mathematik und vielleicht später mal noch Astronomie machen will nur schwer um Linux drum rum kommen....:-)
[quote]
Ich kann Berthold nur zustimmen. Soweit mir bekannt, wird an der RWTH Aachen hauptsächlich Linux oder Varianten davon benutzt. Bekanntestes Linux-Programm ist LaTeX. Mit Windows scheint da nicht viel zu laufen. Die Versionen von Windows wechseln viel zu häufig und sind auch nicht untereinander völlig kompatibel. Ein Wechsel auf eine neuere Version z. B. wegen eines neuen PC ist jedesmal eine Katastrophe. Ich habe auf meinem Notebook Windows 7. Den klassischen Windows-Explorer mit dem Verzeichnisbaum gibt es nicht mehr. Da kannst Du schauen, wo deine Dateien geblieben sind. Wenn außer Bildchen, Videos und Musik noch andere Dinge speicherst, paßt das nicht mehr in das von Microsoft vorgegeben Schema. Windows ist nur noch eine Katastrophe. Man kann froh sein, daß es Linux gibt.
BeitragVerfasst: 10. Mai 2012, 16:56:58 PM
Hallöchen!
Spuckt mir MIDAS auch files aus die man anschließend auch in andere programme einlesen kann, also kein LINUX Format besitzen?Ich denke da an .txt.; .pic; .dat.; .spc.; .jpg etc.?
BeitragVerfasst: 10. Mai 2012, 17:25:31 PM
Hallöchen!
Hallo Dominic,
zumindest .jpg- und .gif Dateien können erzeugt werden.
BeitragVerfasst: 10. Mai 2012, 18:46:58 PM
Hallo Dominic,
Mit .gif liege ich möglicherweise falsch. Ich habe neulich eine gif-Datei aus einer jpg-Datei mittels eines Windowsprogramms (Corel Paint Shop Pro Photo X2) erzeugt. Ich muß diese Frage daher dahingestellt lassen.
BeitragVerfasst: 10. Mai 2012, 19:08:47 PM
Am Donnerstag, den 10.05.2012, 16:56 +0200 schrieb Dominic Freudenmann:
Hallöchen!
Hallo Dominic,
die sogenannten "anderen Programme" verwenden oft ihr eigenes
proprietäres Format. Das wieder von den ganz anderen Programmen nicht
gelesen werden kann.
Midas hat als Privatformat .bdf für Bilder und .tbl für Tabellen. Es
kann diese aber problemlos in das FITS-format umwandeln. Dieses Fits ist
ein wohldefiniertes Format, dessen Definitionen öffentlich bekannt sind.
Wenn ein Windowsprogramm diese nicht lesen kann, dann liegt das meiner
Meinung nach daran, das Windowsprogrammierer sich ungern an freie
Standards halten. Warum? Keine Ahnung.
Midas kann Bilder auch in Postskript ausgeben, ein freier Standard von
Adobe. Frei? Nix gut für Windows!
Eindimensionale FITS und Tabellen kann es auch als ASCII-Daten ausgeben,
Also txt oder dat oder wie Du es auch nennen willst. Einziges Problem
dabei ist der Dezimaltrenner. Der ist immer ein Punkt und kein Komma.
Ein guter Editor kann aber leicht "." durch "," ersetzen.
Gif und jpeg und png und eps und noch vieles mehr kann das schöne
Kommandozeilenprogramm 'convert' ineinander umwandeln, sind alles offene
Standards.
Es gibt überhaupt kein Linux-Dateiformat. Allenfalls das Zeilenende ist
unterschiedlich. Bei Linux genügt ein \n "newline" bei Windows wohl \n\r
"newline carriage return". Damit gibt es aber auch kaum mehr Probleme
beim Austausch Linux <-> Windows.
Ansonsten weiß ich nicht, was ein Linux-Dateiformat ist.
Was ist denn ein Windows-Dateiformat?
Vielleicht ist ein Problem, das bei Linux Betriebssystem und
Anwenderprogramme völlig getrennt sind und bei windows das Betriebsystem
und zumindest die Officesuite untrennbar miteinander verbunden sind.
In einer Schulung über das damals neue XP wurde mir jedenfalls nur über
die Neuerungen in Powerpoint und Outlook etc. berichtet, nix über
Benutzerverwaltung, Rechtevergabe, Active Directory.
Und überhaupt, wer Linux hat braucht nix anderes, weil er damit eh mehr
machen kann, als mit Windoof.
BeitragVerfasst: 10. Mai 2012, 19:31:10 PM
Hallo Günter,
es gibt im professionellen Bereich schon Anwendungen, die nur unter Windows laufen. Aber im großen und ganzen gebe ich Dir recht.
BeitragVerfasst: 10. Mai 2012, 20:23:37 PM
Hallo Günter und Christian!
Vielen Dank für die äußerst informativen Dialoge!Ich werde heute Abend MIDAS installieren und ausprobieren. Falls ich irgendwelche Schwierigkeiten habe, weiß ich ja wo die kompetenten Fachleute sitzen!
BeitragVerfasst: 10. Mai 2012, 21:42:16 PM
Na klar doch midas "kann alles"!!!!!!!!:-)
Und wenn SCHEINBAR nicht , dann hat es einige Experten unter uns die "Alles" wissen.....:-)
Am 10.05.2012 um 16:56 schrieb Dominic Freudenmann <fg-spek-data@vdsastro.de (fg-spek-data@vdsastro.de)>:
Hallöchen!
BeitragVerfasst: 10. Mai 2012, 21:44:35 PM
Soweit mir bekannt, wird an der RWTH Aachen hauptsächlich Linux oder Varianten davon benutzt. Bekanntestes Linux-Programm ist LaTeX. Mit Windows scheint da nicht viel zu laufen. [...] Windows ist nur noch eine Katastrophe. Man kann froh sein, daß es Linux gibt.
ich nehme das Zitat zum Anlass, um mich über die andauernde "Glaubensdiskussion" Windows - Linux aufzuregen!
Tatsächlich ist erstmal festzuhalten, das Win in der freien Wirtschaft Standard ist. Und auch die Uni's (auch die RWTH) nutzen es. Beispiel: Labview zum Kontrollieren des Messaufbauten - ist ein Quasistandard, der gut unter Win läuft. Nebenbei, die Simulaten in meiner Firma nutzen auch "nur" Windows... Win läuft bei mir sehr stabil. Wenn Programme Schwächen haben, kann nicht einfach auf den Rest geschlossen werden! Meine Diss habe ich z.B. auch "geLaText", aber unter Windows. Und noch was: wer von uns nimmt seine Spektren mit einem Windows-Programm auf? Wahrscheinlich alle!
Unix/Linux wird sehr stark in der Naturwissenschaft (z.B. theoretische Physik und eben Midas) benutzt (nur da kann ich es einschätzen). Es hat gewisse Vorteile, keine Frage (z.B. läuft mal nur Midas da). Aber gegen Programmbugs ist auch Linux nicht gefeit.
Mein Appell: Bitte lasst diese unnötigen Glaubensbekundungen über Betriebssysteme. Bringt eigentlich nicht wirklich was. Und seitdem es virtuelle Maschinen gibt, ist alles gar kein Problem mehr. Vielleicht wäre es nur cleverer, Windows unter Linux laufen zu lassen (wegen der Stabilität?!). Da weiß ich aber nicht, ob der VMWarePlayer das kann (VMWare schon, aber kostet aber was...).
Frage an Jürgen N.: Weißt Du da mehr darüber? Ist es VMware Workstation 8 Standard License for Linux and Windows, ESD; Promo Price: $169.15
BeitragVerfasst: 10. Mai 2012, 21:54:57 PM
Ja......obwohl gerade ich das beste Beispiel sein dürfte , für jemanden, der nur Windows konnte und sich entsetzlich schwer tat mit Linux , wenn man das einmal gefressen hat.......Günter hat bei mir da eines ganz elementare Hilfestellung gegeben, dann ist im Rahmen unserer Fragestellungen Linux kaum zu überbieten . Wenn ich dennoch auf Windows da und dort zurückgreife , dann ist das einfach eine gewisse Bequemlichkeit , weil Windows einfach oft eleganter daher kommt. Solche Sachen spielen aber bei " serioesen Astronomen" wahrlich keine Rolle......
Kann halt keiner von denen sein oder werden, deshalb darf ich das auch manchmal versuchen...:-)
Von meinem gesendeteendet
Am 10.05.2012 um 19:14 schrieb Günter Gebhard <fg-spek-data@vdsastro.de (fg-spek-data@vdsastro.de)>:
: Hallöchen!
Hallo Dominic,
Standards.
unterschiedlich. Bei Linux genügt ein n "newline" bei Windows wohl nr
BeitragVerfasst: 10. Mai 2012, 22:09:51 PM
Naja Thomas, wir sind doch hier Amateure dürfen doch wohl zumindest in diesen Bereichen unsere Ansichten sagen, wenn das auch noch gelassen werden soll, na gut , dann macht halt alleine weiter, man sollte sich nicht aeussern , ob jemand einfach eine Tagungsvorbereitung sein lässt , man soll sich sich hier nicht über Vor- und Nachteile von Programmen aeußern .....ueber aktuelle Spektren reden , die in letzter Zeit lediglich von ein oder zwei Leuten selten genug zur Diskussion gestellt werden ist dann das Einzige was erlaubt sein sollte oder über imageslicer, was eh keiner kann........also allmählich nimmt die Forumskultur eher merkwürdige Forderungen an.... das muss ich jetzt schon mal sagen.........
mit Wilhelm Busch und seinem Kaspar Schlich......( falls das überhaupt einer kennen sollte):
"Fatal, fatal bemerkte Schlich, paffte und entfernte sich"........
Am 10.05.2012 um 21:44 schrieb Thomas Hunger <fg-spek-data@vdsastro.de (fg-spek-data@vdsastro.de)>:
Christian Netzel hat Folgendes geschrieben: Soweit mir bekannt, wird an der RWTH Aachen hauptsächlich Linux oder Varianten davon benutzt. Bekanntestes Linux-Programm ist LaTeX. Mit Windows scheint da nicht viel zu laufen. [...] Windows ist nur noch eine Katastrophe. Man kann froh sein, daß es Linux gibt.
BeitragVerfasst: 10. Mai 2012, 23:04:39 PM
Administrator
ja, die gilt für beide Betriebssysteme. Der Key ist derselbe und man lädt sich auf der Herstellerseite die entsprechende Version herunter.
Wem VMWare nicht gefällt kann, auch die Virtual Box unter Linux verwenden. Kostet nix!
Es gibt auch unter Linux Aufnahmesoftware. Hier z.B. eine, die auch im FITS-Format aufnehmen und FITS-Header beschreiben kann:
http://arnholm.org/astro/software/wxAst ... UX_INSTALL
Ich mache genau das seit ca. 2 Monaten. Ich verwende Ubuntu 11.10 / 64 Bit und lasse Win 7 64 Bit in einer virtuellen Maschine laufen, solange ich noch Windows-Software brauche.
Erstaunlicherweise hat Ubuntu 64 Bit meine z.T. alten Videokarten/Framegrabber und auch die ToUCam Pro (für die es für Win 7/64Bit keine offiziellen Treiber mehr gibt) sofort erkannt und alle Treiber installiert.
Es gibt Software, mit der man die Video-Geräte konfigurieren kann, z.B. guvcview.
Ich habe den Eindruck gewonnen, dass Ubuntu die Rechnerressourcen schonender nutzt als Windows. (Aber das kann ich nicht durch Messungen belegen). Außerdem muss ich nicht mehr defragmentieren und einen Virenscanner brauche ich mangels Linux-Viren (es gibt aber welche) auch nicht mehr. Das Betriebssystem habe ich auf einer SSD installiert und das /home und einige andere platzfressende Verzeichnisse auf großen SATA-Platten eingehängt. Meine windows-formatierten Festplatten habe ich gelassen, wie sie waren, weil Ubuntu und andere Distributionen mittlerweile auch NTFS-formatierte Festplatten lesen und beschreiben können.
Für NVidia- und ATI-Grafikchips kann man sich die Treiber automatisch installieren lassen und problemlos mehrere Bildschirme betreiben. Das AMD Catalyst Controlcenter z.B. gibt es auch für Linux. Evtl. sollte man nicht gleich nagelneue Hardware mit aktuellsten Chipsätzen verwenden, da es nicht immer sofort Linux-Treiber dafür gibt.
Gruss Jürgen
Zuletzt geändert von Jürgen Neubert am 10. Mai 2012, 23:11:26 PM, insgesamt 1-mal geändert.
BeitragVerfasst: 10. Mai 2012, 23:10:23 PM
wenn Du Windows unter Linux laufen lassen willlst, kannst Du als Alternative auch VirtualBox (https://www.virtualbox.org/) verwenden. Freeware von Oracle, läuft sehr gut bei mir (auf einem Win7 Host). Dank der Unterstützung von Jürgen kann ich jetzt auch Linux verwenden, bin aber noch nicht gross dazu gekommen. Im übrigen bin ich ganz Deiner Meinung, dass die Glaubenskriege nicht viel bringen, ich verwende zwar meistens Windows, aber für fast alles gibt es auch Linux Programme, so kann man man z.B. Spektren mit Audela aufnehmen (gibts für Windows und Linux). Wäre eine Möglichkeit, um von Windows umzusteigen.
Gruss, Martin
BeitragVerfasst: 10. Mai 2012, 23:39:26 PM
mir liegt es wirklich fern, hier einen Glaubenskrieg zu führen. Tatsache ist aber, daß es seit Windows XP erhebliche Änderungen in der Oberfläche gegeben hat, deren Sinn ich nicht einsehe. Ich habe nirgends behauptet, daß Windows instabil ist. Nur die diese ewigen und sinnlosen Änderungen kosten einfach zu viel Zeit und soweit es kommerzielle Nutzungen betrifft auch zuviel Geld. Ich ärgere mich einfach nur über Windows schwarz. Mit Glaubenskrieg hat das wirklich nichts zu tun.
BeitragVerfasst: 11. Mai 2012, 09:33:23 AM
Hallo zusammen! Linux oder Windows ist ein ewiges Thema. Wir alle wissen, dass jeder seinen besten Weg finden muss. Wenn danach gefragt wird, werden keine Glaubensbekenntnisse abgegeben, sondern wahrscheinlich nach eigener Erfahrung geantwortet. Das ist gut so! Daher mag das für manche ermüdend sein, doch wenn jemand danach fragt und darauf wird geantwortet, ist das nun einmal ein Thema für die FG. Und da ja viele Antworten gegeben werden, besteht auch keine Gefahr der "Software-Ideologie". Also weiter diskutieren.
BeitragVerfasst: 11. Mai 2012, 10:33:38 AM
Das hatte ich nicht iwe so gedacht :D
Ich habe gesehen dass dieses Wasserlinnie Menu im ISIS gleisch wie im VSPEC ist.
BeitragVerfasst: 11. Mai 2012, 18:37:56 PM
........ Tatsache ist aber, daß es seit Windows XP erhebliche Änderungen in der Oberfläche gegeben hat, deren Sinn ich nicht einsehe.
Seit Windows 2000 kann ja JEDE Windowsoberfläche in der klassischen
Ansicht dargestellt werden. So bleiben Bedienungsänderungen bei
Systemwechsel aus.
Der Explorer, den ich über alles liebe und dessen intuitive
Bedienung prima gelöst ist, ist oftmals Stein des Anstoßes.
Hier trauert die Generation, die mit DOS groß geworden ist immer noch
dem NortonCommander hinterher. Den gibts immer noch
und ist als Totalcommander im Netz findbar.
Neues ist immer besser als Altes.
Alte Programme lassen sich unter Windows 7 im XP Modus
starten.
So werden die Nutzer, die ein neues System ohne Neugier und ohne
Intuition bedienen unter Windows 8 dann besonders gefordert.
Dort fehlt sogar der Startbutton. Windows 8 ist an die
Bedienung des Windows Phone 7.5 smartphones angepasst.
Aber auch hier gibt es die passende Klassik-Einstellung des Bildschirms
Gruß, Rainer
BeitragVerfasst: 12. Mai 2012, 09:14:29 AM
Thank you very much. I was able to find the issue and fix a never reported bug...
Your file is very long, that's why nobody complaints maybe. And the file management was bugging with a data set above 32768 values... in some procedures. I have some "workaround" but the best is to fix it.
Now you have a new version on the site to download 4.0.8
http://www.astrosurf.com/vdesnoux/download2.html
Thanks for your patience !
Valerie
Ok......mehr sage ich nun hierzu nicht mehr......
BeitragVerfasst: 21. August 2014, 21:23:01 PM
hatte wieder das Problem mit Vspec und Win7 nach einer Neuinstallation.
Für den Fall, wenn es nicht gleich geht!
Wie es auf der Seite von astrosurf steht vorgehen.
http://www.astrosurf.com/vdesnoux/download1.html
Programm als Administrator installieren, danach das Icon mit rechter Maus anklicken und "als Administrator ausführen".
Das war's.
BeitragVerfasst: 22. August 2014, 00:57:23 AM
ich komme inzwischen im VSpec relativ unfallfrei durch den Workflow. Nerven tut mich eigentlich nur,
dass VSpec mir immer die Ländereinstellung für Dezimalpunkt/komma zerhaut und ich dann parallel im Excel Probleme bekomme.
Das ist einfach repariert - stört aber echt. Dafür gibt es vermutlich keine einfache Lösung.
Ulrich
