Hallo !
ich habe die Möglichkeit einen gebrauchten Spectrometer von Zeiss Jena zu erwerben. Kann aus seinen Teilen ein Astro Spectrometer gebaut werden, oder macht das wenig Sinn?
Hier die Parameter:
Spectrometer SPECORD M40
VEB Carl Zeiss JENA
Technical description:
Spectral range: 54000 -11000 cm-1
Type: double beam
Optics: Dual monochromator for UV range:
Preliminary monochromator: diffraction grating, 1302 scratch/mm
Main monochromator: diffraction grating, 1302 scratch/mm
Grating-filter monochromator for VIS range:
diffraction grating, 651 scratch/mm
Filters:
Interferencing filters: 31000 - 25000 cm-1
stained glass WK 36: 25000 - 19500 cm-1
stained glass GA 48: 19500 - 14000 cm-1
stained glass RA 67: 14000 - 11000 cm-1
Light sources: Deuterium lamp D2E - UV range
halogen lamp 6V 20W - VIS range (preliminary aligning)
Detector: photomultiplier
accuracy of wave number: 3 cm-1 (0.25 nm) for 11000 cm-1
10 cm-1 (0.03 nm) for 54000 cm-1
Reproducibility of wave number: 5 cm-1 (0.02 nm) for 54000 cm-1
1.5 cm-1 (0.1 nm) for 11000 cm-1
Photometrical accuracy: 0.005 when E=1 (20000 cm-1, INT=10s, G=5)
Scattered light: <0.01% for 45 454 cm-1 (220 nm) (1% solution of sodium iodide)
DSC00574e.jpg [ 63.87 KiB | 2877 mal betrachtet ]
