Aktuelle Zeit: 09. Februar 2026, 21:34:27 PM
 Betreff des Beitrags: NEW ECHELLE THE "LINX"
BeitragVerfasst: 28. Februar 2017, 19:39:33 PM
Hello to all,
I have finished the mechanical part of the new Echelle, the LINX.
The LINX is very similar to Mussol. The only difference between the transmission grating 300 l/mm (200 th Mussol) and the mark of objective, a NIKKOR (Mussol, an old-ASAHI PENTAX).
It is now to build the module guide.
Regards, Joan.
LINX MECANICA-1.jpg [ 287.11 KiB | 2818 mal betrachtet ]
LINX MECANICA-2.jpg [ 243.26 KiB | 2818 mal betrachtet ]
 Betreff des Beitrags: Re: NEW ECHELLE THE "LINX"
BeitragVerfasst: 21. Mai 2017, 14:49:43 PM
Hello,
This is a test of the Linx, done in daylight (wavelength is not calibrated correctly). There is still work to do all the settings work correctly, but the first impression is optimistic.
Regards, J. Guarro.
_dia1_20170520_654_J. Guarro.png [ 89.02 KiB | 2747 mal betrachtet ]
BeitragVerfasst: 24. Mai 2017, 19:50:53 PM
Hello all,
These two graphs are the first light of Linx. The wavelength is now correctly calibrated.
The Linx is still in beta, it is intended for the telescope REMOT of Sta. Maria M. Its dynamic range is from 4046 to 7744 Angstroms. The provisional resolution is R = 8000.
Regards, Joan.
HD155763-1.png [ 24.34 KiB | 2723 mal betrachtet ]
MIZAR-2.png [ 26.06 KiB | 2723 mal betrachtet ]
BeitragVerfasst: 29. Mai 2017, 20:46:23 PM
Hello,
This is the result of de simultaneous observation of the star VV Cep, by Mussol spectrograph from Piera and the Linx in Sta. Maria M., ( to 70 Km. of distance ).
The Linx's provisionally resolution is R=8000, tomorow I go to Sta. Maria M. with the intention it could improve.
Regards, J. Guarro.
_vvcep_20170524_923_J. Guarro1.png [ 99.9 KiB | 2699 mal betrachtet ]
_vvcep_20170524_923_J. Guarro2.png [ 36.35 KiB | 2699 mal betrachtet ]
_vvcep_20170524_923_J. Guarro3.png [ 34.22 KiB | 2699 mal betrachtet ]
BeitragVerfasst: 01. Juni 2017, 11:22:01 AM
Hello,
Regards, J. Guarro.
Hello Jean,
looks very fine!
Is there a potential of improvement of the resolution? What R is the theoretical guess? How is the R at the edges of the spectrum in blue and red compared with the green range (optimum of the lens)?
BeitragVerfasst: 01. Juni 2017, 17:07:47 PM
I changed the collimator of D30mm. F100mm. , by another of D30 125 mm. and the LINX in increased the resolution to R = 9000.
Being attached, the resulting TXT reducing ALPHA CRB. The R of each individual Order, it is the result of several variables, including the variable of focussing.
I'm thinking back to increase the R of the LINX, putting a collimator 150 mm. But he might lose light. I prefer less resolution and to reach magnitudes weaker ....
Regards, Joan.
_alp crbtxt.png [ 52.4 KiB | 2666 mal betrachtet ]
_ALP CRB9..png [ 23.89 KiB | 2666 mal betrachtet ]
BeitragVerfasst: 06. Juni 2017, 19:44:52 PM
Hi,
I present the comparison of two graphs, the star VV Cep. One is with the Linx from Sta. Maria and second with the Mussol from Piera.
The reason is a test to check the stability and confidence of both Échelles.
You know that VVCep is an M2, with little emission in the blue.
In the graph, from 4052 to 4175 Angs., The background noise is confused with the image (to improve the result and need more exposure time), the result is bad.
In the graph, from 4175 to 4300 Angso., The coincidences begin to be evident from the 4200 Angs.
In the graph, from 4300 to 4425 Angso. I think that I can improve.
Regards, J.Guarro.
_vvcep_20170605_962_J. Guarro.png [ 13.84 KiB | 2643 mal betrachtet ]
_vvcep_comparacio1.png [ 12.37 KiB | 2643 mal betrachtet ]
_vvcep_comparacio2.png [ 11.34 KiB | 2643 mal betrachtet ]
_vvcep_comparacio3.png [ 11.28 KiB | 2643 mal betrachtet ]
