Aktuelle Zeit: 10. Februar 2026, 01:25:04 AM
 Betreff des Beitrags: Mini White Pupil
BeitragVerfasst: 19. September 2017, 16:15:43 PM
Hi,
I've assembled a white-pupil spectrograph out of Thorlabs components and two off-axis parabolas (OAP) from an old spectrometer. The mirrors have a focal length of around 200 mm and an off-axis angle of 7 degree. The instrument is fed by a single-mode fiber with ~3 micron core diameter and operates in the visible wavelength range. it almost fits into a shoe box.
Enjoy :wink:
Cheers,
Tobias
white-light spectrum.jpg [ 481.9 KiB | 8242 mal betrachtet ]
spectrometer.jpg [ 372.02 KiB | 8242 mal betrachtet ]
 Betreff des Beitrags: Re: Mini White Pupil
BeitragVerfasst: 19. September 2017, 16:40:06 PM
Was ist das " Mini Whiteboard pupil"?
hG
BeitragVerfasst: 19. September 2017, 17:29:45 PM
Es geht um einen Spektrographen im "white pupil"-Design:
The “Pupille Blanche” principle, a term coined in the early 1970s by André Baranne for a novel spectrograph concept, where the beam dispersed by the grating is re-collected by the collimator optics to produce an image of the grating (the white pupil — white because here all the dispersed beams overlap again), where the camera or cross-disperser is placed. The second pass through the collimator may be thought to be a waste of photons, but compared to more traditional designs, the overall efficiency is actually improved, because the camera mouth can be placed very close to the second pupil, which eliminates vignetting. The concept also allows the grating to be used with a small angle between inci­ dent and diffracted beams, which maxim­ ises the diffraction efficiency. There is also the additional design freedom to tune the diameter of the white pupil.
https://www.eso.org/sci/publications/me ... 136-13.pdf
BeitragVerfasst: 19. September 2017, 17:58:07 PM
Hallo Tobias,
trotz Deiner Bilder und Otmars Erklärung verstehe ich den ganzen Aufbau nicht. Welche Lichtquelle hast Du benutzt? Könntest Du bitte noch mit einer Skizze den Strahlenverlauf erläutern.
 Betreff des Beitrags: Re: Re: Mini White Pupil
BeitragVerfasst: 20. September 2017, 01:15:01 AM
Christian,
The white pupil configuration is very well explained in Appenzeller's "Introduction to Astronomical Spectroscopy", p84. It is also shown in Eversberg & Vollmann's "Spectroscopic Instrumentation", p276.
I'll try to get a copy of the optical layout (See attached)
white_pupil.jpg [ 185.18 KiB | 8042 mal betrachtet ]
2017-09-20 1:58 GMT+10:00 Christian Netzel <fg-spek-tech@vdsastro.de>:
Link zum neuen Beitrag: http://forum.vdsastro.de/viewtopic.php?t=4919#p30282
Hallo Tobias,
BeitragVerfasst: 20. September 2017, 02:26:29 AM
Hi Christian
Hallo Tobias,
Strahlenverlauf ist angehaengt. Das Ding wo die Faser drinne steckt ist ein reflektiver Faserkollimator (oder eben eine off-axis Parabel), dahinter im kleinen schwarzen Tubus befindet sich ein Achromat mit 60 mm Brennweite, beide zusammen aendern das f-ratio der Faser von schnell zu langsam. Der divergente Beam trifft auf den OAP 1, wird kollimiert und aufs Echelle umgelenkt. Vom Echelle gehts wieder zurueck auf den OAP1, dann wird der Beam fokusiert mit dem Spiegel auf den zweiten OAP umgelenkt welcher wieder einen kollimierten Beam erzeugt. Lichtquelle ist eine Weisslichtquelle welche man fuer Flats verwendet. Das aufgezeigte System ist ein 1:1:1 Relay wobei OAP1, OAP2 und Camera etwa dieselbe Brennweite haben. Bei groesseren Multimode Spektrographen ist die Kamera ueblicherweise ziemlich schnell.
Hoffe das hilft irgendwie
Als Lichtquelle hab ich eine Weisslightquelle verwendet.
Gruesse,
Tobias
WP_test.png [ 220.94 KiB | 8200 mal betrachtet ]
BeitragVerfasst: 20. September 2017, 08:35:18 AM
Hallo Tobias,
ich hab' auch mal eine Frage zu dem interessanten White Pupil Concept:
Man ließt ja häufiger, dass Echelle-Spektrografen unter Streulichtproblemen leiden. Bei Streulichtproblemen in Optiken kann man z.B. einen Zwischenfokus erzeugen und genau dort eine möglichst enge Blende als Raumfilter platzieren. Bei dem White Pupil Echelle ist ja genau diese Voraussetzung gegeben. Wäre es nicht sinnvoll wenn man genau auf Fold1, also am Ort des Zwischenfokus, diese Blende anbringen würde ?
Klaus
BeitragVerfasst: 20. September 2017, 09:04:52 AM
Hallo Klaus,
Das hast Du richtig erkannt. Üblicherweise platziert man bei einem "white pupil"-Spektrographen an der Stelle eine Streulichtblende.
BeitragVerfasst: 20. September 2017, 09:25:43 AM
Hi Klaus,
hat man so auch schon gemacht (z.B. beim FOCES Spektrograph) wobei der Zwischenfokus hier, durch den Versatz der OAPs etwas hinter dem Fold liegt.
https://aas.aanda.org/articles/aas/full ... /img18.gif
BeitragVerfasst: 20. September 2017, 09:38:35 AM
Hallo Tobias,
warum ein solches Design für einen so "kleinen" Spektrographen? Könntest Du den Vorteil zu einem "klassichen" Design hier erläutern?
Neben den genannten Vorteilen des WP-Aufbaus sehe ich den, dass die Brennweite des Transferkollimators (Dein zweiter OAP) normalerweise kleiner gewählt wird, um den Beamdurchmesser an der optischen Kamera zu verkleinern. Das hat den Vorteil, dass Selbige und der CD geringere Abmessungen haben können. Dafür muss aber die Dispersion des CD stärker sein.
Der große Nachteil eines solchen Aufbaus ist die i.d.R. starke Bildfeldkrümmung in einer Richtung, was immer den Gebrauch eines toroidalen Fensterns kurz vor der CCD erforderlich macht. Wie hast Du das hinbekommen? Es gibt natürlich noch den Ansatz eines Mangin Spiegels nahe des WP-Fokus, aber das wäre dann wieder eine Sonderfertigung.
LG,
D
BeitragVerfasst: 20. September 2017, 10:01:49 AM
Hi all, this is depicted in our book on page 297. From my point of view Tobias' design does not take the white pupil design into perfect account, if the draft is true to scale. The cross disperser should (could?) be positioned closer to the intermediate focus "...because the camera mouth can be placed very close to the second pupil, which eliminates vignetting.".
WhitePupil.JPG [ 91.55 KiB | 8179 mal betrachtet ]
BeitragVerfasst: 20. September 2017, 14:31:02 PM
- sehr kleiner gamma Winkel (1-1.5 Grad) --> effizienter
- keinen Wellenlaengenabhaengigen gamma Winkel wie bei einem Littrow Echelle (wird uebel in der Datenreduktion wenn man mehrere Fasern verwendet)
- Kameradesign wird entspannter da das Licht nur einmal durch geht
Stimmt, ist hier aber nicht noetig da der Stahl ohnehin schon klein ist (etwa 15 mm 1/e^2). Leider wird die Kamera dann auch wieder komplexer.
Mangin Spiegel sind ganz uebel zu justieren! Kamerafenster hab ich noch nicht gerechnet oder eben mal ausprobiert. Ob das bei einer Brennweite von 400-500 mm wirklich eine groesse Rolle spielt weiss ich nicht. Bildfeldkruemmung ja, muss mal schauen .... wollte erstmal sehen ob die Spiegel was taugen :)
BeitragVerfasst: 20. September 2017, 14:46:21 PM
irgendwie verstehe ich Dein WP Design nicht. So wie das ausschaut befindet sich der Cross-disperser zwischen OAP 1 und OAP 2, das heisst im divergenten Strahl?
Ist auch schon spaet hier .... :?
wp.png [ 404.22 KiB | 8162 mal betrachtet ]
BeitragVerfasst: 20. September 2017, 15:42:17 PM
Hi Tobias, wenn ich das richtig verstehe, ist der Cross-Disperser doch immer im divergenten Strahl nachdem das Licht am Echelle gebeugt wurde. Gruß, Thomas
BeitragVerfasst: 20. September 2017, 16:25:35 PM
Das hast Du nicht richtig verstanden :-) Das Gitter macht den Strahl nicht divergent.
BeitragVerfasst: 20. September 2017, 17:42:25 PM
Hallo Otmar, vielleicht verstehe ich das ja nicht, doch wenn der Strahl dispergiert würde ich ihn als divergent bezeichnen. Die Farben werden nicht parallel verlaufen. Der Cross-Disperser ist auch im oberen Teil meiner Abbildung nicht im parallelen Strahl. Aber vielleicht bin ich ja auf dem Holzweg. :lol:
BeitragVerfasst: 20. September 2017, 19:28:33 PM
Das Echelle-Gitter macht natürlich eine Winkeldispersion, das ist klar. Aber Strahlen gleicher Wellenlänge sind nach dem Echelle immer noch parallel und müssen es auch vor dem Cross-Disperser sein. Daher funktioniert Deine Skizze für den "white pupil spectrograph" so nicht. Du musst wie im Strahlengang von Tobias zweimal durch den Kollimator.
BeitragVerfasst: 21. September 2017, 08:59:28 AM
Jetzt verstehe ich, Otmar, so betrachtet stimmt das. Dann wäre aber auch die erste Skizze falsch, meine ich. Es kommt darauf an, was man darstellen möchte. Hätten wir durchgehend parallele Strahlengänge, müsste die Kameraoptik nicht größer sein als der Kollimator. Gruss, Thomas
BeitragVerfasst: 22. September 2017, 08:33:51 AM
Welche Skizze meinst Du?
Gruss,
Tobias
BeitragVerfasst: 22. September 2017, 10:49:56 AM
Hi Tobis, ich meine meinen Beitrag am 20. September 2017, 10:01:49 AM. Gruß, Thomas
