Aktuelle Zeit: 20. Januar 2026, 15:36:06 PM
 Betreff des Beitrags: ISIS and my echelle
BeitragVerfasst: 17. September 2017, 16:04:08 PM
Rather than hijack Daniels thread I will respond to Bernard here.
I had used ISIS with the first version of my spectrograph which used an echelle with the same characteristics as the eShel. However, when I updated it for my new telescope to a larger echelle I saved money by getting an over stocked grating but it had a different blaze and lines/mm to teh eShel.
I tried to use ISIS and worked at it for a considerable time but I could not get past the camera rotation stage and the setting of the alpha and gamma angles and hence the assignment of the orders. See figures 22 to 26 here http://www.astrosurf.com/buil/isis/eshel/tuto1.htm
I assume this was because ISIS used a model based on the spectrograph characteristics. However, I could not prove this.
In the end I decided to use IRAF and got that working with help of this forum.
Regards Andrew
 Betreff des Beitrags: Re: ISIS and my echelle
BeitragVerfasst: 18. September 2017, 00:20:06 AM
Hi Andrew,
Your ISIS 'failure point' is where I assumed it would be. A couple of years
ago I tried to help Carl Sawicki use ISIS to reduce his SQUES (with Relco
cal line) ecelle spectra and that is where we also floundered. I recently
changed my eShel camera from an ST-8 (KAF-1603) to a QHY22 (ICX-694) and it
took a lot of fine tuning of the camera rotation angle and messing with the
alpha and gamma values before it all worked well. While I can't be 100%
confident I do feel that if we had persisted we could have got it to work
with ISIS, as I see no obvious reason why the programme could not handle it.
Cheers,
Bernard
-----Original Message-----
Sent: Monday, September 18, 2017 12:04 AM
To: fg-spek-admin@vdsastro.de
Subject: [fg spektroskopie] ISIS and my echelle
Link zum neuen Beitrag: http://forum.vdsastro.de/viewtopic.php?t=4918#p30258
forum.
Regards Andrew
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Quicquid Nitet Notandum
BeitragVerfasst: 18. September 2017, 09:58:57 AM
Hi Andrew,
Cheers,
Bernard
Hi Bernard, I did not easily give up on ISIS. I spent considerable time trying different rotations and angles in a systematic manner. However, I could not get close. I reasonably sure that it is because ISIS uses a model of the echelle based on the eShel grating to decide which calibration lines should be in which order and where. I conclude that this is not compatible with my grating. I also had used the RELCO lamp with success with my initial echelle.
I then under took the adventure of learning Linux and IRAF to the point where I can simply reduce my spectra so I am less motivated to revisit ISIS again for this. However, given the almost constant cloud we now seem to have I may try again. However, Daniels new software may take priority.
I am currently building another echelle of higher R and a design close to CB's VHIRES and so will use IRAF for this as well.
Thanks for your interest and help.
Regards Andrew
BeitragVerfasst: 19. September 2017, 01:36:39 AM
I have two echelle spectrograph, one is an eshel from Shelyak, the second is a prototype of Eshel+ (R about 30000).
For this two spectrographs, I use ISIS to reduce the data of course with different parameter and it work well.
But it's difficult to find the right parameters and also the right exposure time for the Th/Ar lamp.
 Betreff des Beitrags: Re: Re: ISIS and my echelle
BeitragVerfasst: 19. September 2017, 04:45:01 AM
Hi Olivier,
Thanks for the confirmation that ISIS can handle non-eShel instruments,
which is what I thought.
Cheers,
Bernard
Sent: Tuesday, September 19, 2017 9:36 AM
Subject: [fg spektroskopie] Re: ISIS and my echelle
Link zum neuen Beitrag: http://forum.vdsastro.de/viewtopic.php?t=4918#p30268
BeitragVerfasst: 19. September 2017, 10:41:41 AM
Oliver I know the Eshel+ is different to the eShel but do the gratings have the same lines/mm and blaze angle ?
If they are different then it would be worth me trying again.
Thanks Andrew
BeitragVerfasst: 19. September 2017, 13:52:45 PM
On further thinking about this I suspect it may have been the physical rotation of the camera that gave me the issues I had. Certainly ISIS has all the data needed to account for different gratings
At the time I was using an FLI Microline which has a square casing. In view of this I probably did not try hard enough to align the "four Th Ar lines" horizontal.
I now use a SX camera so it could be rotated so I will revisit ISIS.
Thanks for the stimulus.
Regards Andrew
BeitragVerfasst: 19. September 2017, 14:40:01 PM
From my own, and other's, experience the physical orientation (rotation) of
the camera is all important, and needs very fine tuning, to get everything
working. Despite published advice to set the 'four ThAr lines' horizontal I
had to set them a bit 'off' to achieve alignment.
Cheers,
Bernard
BeitragVerfasst: 19. September 2017, 15:03:27 PM
ISIS Th Ar.png [ 127.1 KiB | 1848 mal betrachtet ]
Cheers,
Bernard
I think this is my problem as the 4 lines are at the extrems of the of orders 34 and 35 with my grating see attached.
 Betreff des Beitrags: Re: Re: Re: ISIS and my echelle
BeitragVerfasst: 19. September 2017, 15:30:02 PM
Andrew,
Using way off-centre lines may indeed be the main problem. As ISIS allows
you to define a different ref line, and set of rotation lines, I suggest you
select a good line near the centre.
Cheers,
Bernard
Sent: Tuesday, September 19, 2017 11:03 PM
Subject: [fg spektroskopie] Re: Re: ISIS and my echelle
Link zum neuen Beitrag: http://forum.vdsastro.de/viewtopic.php?t=4918#p30276
(rotation) of
everything
horizontal I
Cheers,
Bernard
BeitragVerfasst: 19. September 2017, 17:10:35 PM
Thanks Andrew
Andrew,
Here's the difference between eshel and ESP gratings :
ESP :
52,4 grooves per mm
Alpha : 65 deg
Gamma : 4 deg
Eshel :
79 grooves per mm
Alpha 63.1 deg
Gamma : 5.75 deg
BeitragVerfasst: 20. September 2017, 14:56:41 PM
Thanks Olivier, your ESP grating is close to mine. Mine has a blaze of 63.5 deg and 52.67 l/mm. I got the orders wrong in my previous post as I was quoting my original version of MRes. The orders should have been 51 and 52 for the "Four Th" lines.
Looking at the data still in ISIS from my attempts I did use different reference lines but I found an error in the order assignment.
I will try again with ISIS with the correct order this time.
Thanks Andrew
