Aktuelle Zeit: 27. Juli 2021, 13:28:38 PM
 Betreff des Beitrags: Comet 4P/Faye
BeitragVerfasst: 19. Mai 2021, 14:03:47 PM
Hello All,
These images of 4P/Faye were collected at the beginning of morning twilight on 18 May 2021 so the tail is a little washed out. Comet 4P/Faye was magnitude 15.2 with a 25" coma and a tail at least 95" PA 241 degrees. It appears the comet will brighten to magnitude 10 as predicted when it makes it's close approach to Earth in December. The MPC ephemeris was wrong, the JPL ephemeris was correct for 4P on 05/18. The comet was found 12.3 arc minutes at PA 76 degrees from the MPC predicted ephemeris. I should note that I use the ephemeris generated by the MPC for the Guide software.
4P_20210518_1103_molason.jpg [ 290.51 KiB | 297 mal betrachtet ]
Cheers, Mike
:lol: Arizona
 Betreff des Beitrags: Re: Comet 4P/Faye
BeitragVerfasst: 01. Juni 2021, 13:06:56 PM
Hello All,
Managed to get some images of Comet 4P/Faye before morning twilight on 23 May 2021. The comet is magnitude 14.9 with a nice tail 3' 7" long at PA 250 degrees with a 20" coma. This may be a nice comet this summer and fall as it brightens to magnitude 10 later this year.
4P_20210523_1024_molason.jpg [ 301.9 KiB | 170 mal betrachtet ]
Cheers, Mike
:lol: Arizona
