Aktuelle Zeit: 22. Oktober 2021, 15:11:46 PM
 Betreff des Beitrags: Ausbruch - 29P/Schwassmann-Wachmann
BeitragVerfasst: 26. August 2021, 06:37:50 AM
In der Mailingliste wird berichtet, dass Jean-François Soulier und Pieter-Jan Dekelver einen Ausbruch um 2 Größenklassen beobachtet haben. Die von ihnen gemessene Kernhelligkeit stieg auf 14,5 bis 15 mag. Angaben zur Gesamthelligkeit finde ich nicht.
Der Komet steht im Fuhrmann, hoch am Morgenhimmel.
As reported by Jean-François Soulier from Dauban, France, comet 29P/Schwassmann-Wachmann 1 is in outburst! Estimated time of outburst was at 2021 August 24.96 +/-0.01
I have observed the comet on the night of 23 to 24 August 2021, when there was nothing out of the ordinary. At a steady pseudo nucleus magnitude around magnitude 17.0 On the night of 24 to 25 August 2021, I observed the comet about 2 hours after the outburst (not knowing about the outburst).
The pseudo nucleus magnitude was then around mag. 15.0. Also the Af(Rho) value has doubled! Hopefully I can manage to do one more observation next night… Stay tuned.
*** Equipment ***
0.30-m f/4 Newtonian reflector + CCD FLI Microline KAF3200ME with full SLOAN set + JC.-R and -V / 10Micron GM2000HPS
Detailed information about equipment and scientific information inside the image.
BeitragVerfasst: 26. August 2021, 09:37:04 AM
Hello Uwe,
So I collected these images on 4 August 2021 when they reported the comet was around magnitude 17. That is not what my data showed, the coma was about 30". I used a 38" aperture diameter which Astrometrica gave a G=15.4 and for a 31" diameter aperture it gave a G=15.5. If I only look at the central core of the coma and use a aperture diameter of 11" then Astrometrica says G=16.8. So when they say that the pseudo nucleus magnitude increased by 2 they are simply looking at the core of the coma? I like the way that Erik Bryssinck shows his magnitude data, he gives the resulting magnitude for up to 8 different aperture radii which definitely shows what a big difference the aperture radius makes in determining a comet's magnitude. The comet is much brighter than what they usually report which is very misleading.
29P_20210804_1020_molason.jpg [ 242.33 KiB | 1414 mal betrachtet ]
Cheers, Mike
:lol: Arizona
BeitragVerfasst: 26. August 2021, 11:12:53 AM
Dear Mike, as far as I know most magnitude measuring use a 10 arsec aperture. This is the most common aperture for Afp values.
BeitragVerfasst: 26. August 2021, 12:17:48 PM
Hello Uwe,
So Afp values do not measure the true magnitude of a comet, just the central 10" of the coma. So unfortunately these Afp values show up around the world as the true magnitude of a comet when they are not. They work fairly well for very faint comets with little or no coma but not for a comet like 29P. That explains why one sees such big discrepancies in comet magnitudes, these Afp values are getting mixed in with comet magnitudes that attempt to measure the full extent of the comet brightness to include all of the coma. Does the German Comet Group prefer Afp values for magnitude estimates or the use of an aperture to include all of the comet's coma that one can see in an image? There does not seem to be much of a standard for measuring a comet's magnitude, if one does not mention the aperture being used then the magnitude estimate does not seem to have much value when compared to other magnitude estimates. Thank you for the information Uwe.
Cheers, Mike
:lol: Arizona
BeitragVerfasst: 26. August 2021, 12:58:18 PM
Dear Mike, I know that and our group developed a cure for that: AIRTOOLS. Our Thomas Lehmann collected a bunch of tools which make the calculation of total magnitude easy, even at large apertures. Thomas and Steffen Frithsce use that regularely.
BeitragVerfasst: 07. September 2021, 07:46:06 AM
Atel 14898 berichtet von einerm erneuten Ausbruch um eine Größenklasse zum 5. September.
https://www.astronomerstelegram.org/?read=14898
Auf COBS gibt es eine Messung vom 4.9. (Sandor Szabo) mit 14m3 und dann eine von unserem Walter Kutschera von vorgestern 12m6. Es lohnt sich hinzuschauen.
Walter hatte aber auch schon am 3.9. beobachtet, unsicher 12m2. Er schrieb
3.9.: Koma mit verschobenen Kernleuchten; Mondaufgang stört
6.9.: Koma etwas kleiner, Kernleuchten rückläufig
BeitragVerfasst: 07. September 2021, 12:39:39 PM
Ob das jetzt ein neuer Ausbruch ist, bezweifle ich. Ich habe kernnah am 1.9. 15.4 mag gemessen, am 5.9. 15.3 mag. Die Koma ist dabei gewachsen, wie es sich für das Ausbildung der Spiralform gehört. Für mich sieht das nach einem Ausbruch aus.
Werner
BeitragVerfasst: 07. September 2021, 18:59:12 PM
Das legen ja auch Walters Beobachtungen nahe.
BeitragVerfasst: 29. September 2021, 07:25:42 AM
Auf der Mailig-Liste wird wieder über einen Ausbruch diskutiert. Ein Drei- oder har Vierfach-Asubruch diesmal.
Outburst at 2021 09 25.340 +/-0.005 16.90R => 14.43R Intensity ~1
Outburst at 2021 09 26.15 +/-0.12 14.45R => 13.73R Intensity ~1
Strong outburst at 2021 09 26.98 +/-0.05 13.75R => 12.40R Intensity ~5
Very strong outburst at 2021 09 27.68 +/-0.06 12.40R => 11.25R Intensity ~12
Richard Miles, BAA
Laut elektronischen Messungen sollte der Komet etwa 11 mag haben. Es gibt zu wenige visuelle Messungen, also: Mal hinschauen. 29P steht im Fuhrmann, da stört der Mond freilich noch. Ab der Nacht zum Freitag sieht es besser aus, z.B. Do/Fr bei Mondaufgang gegen halb 1 in 30 Grad Höhe.
BeitragVerfasst: 30. September 2021, 07:31:45 AM
Auch Atel 14943
https://www.astronomerstelegram.org/?read=14943
BeitragVerfasst: 01. Oktober 2021, 06:38:50 AM
Nick James sieht 3 Jets.
BeitragVerfasst: 02. Oktober 2021, 12:45:54 PM
Die innere Koma ist inhomogen. Die äußere Koma ist etwas grünlich, also nicht nur Staub. Bild vom 2.10
29P20211002UT0010sec12x240w.jpg [ 2.9 MiB | 883 mal betrachtet ]
BeitragVerfasst: 02. Oktober 2021, 13:21:05 PM
Ich habe 29P gestern visuell auf 11.0 mag geschätzt. Nur 2007 und 2009 war er für mich noch etwas heller. Mal sehen, wie hell er diesmal wird. Die CCD-Kamera hat es schon nach 20 sec gesättigt.
Werner
BeitragVerfasst: 04. Oktober 2021, 20:00:53 PM
Ich habe Dauergrau und Nieselregen...
Momentan vertröstet mich die Wetterprognose auf das Wochenende.
BeitragVerfasst: 07. Oktober 2021, 08:15:57 AM
Endlich hat es geklappt und ich hatte klaren und mondfreien Morgenhimmel. Um diese Jahreszeit sind Morgenbeobachtungen leicht, weil ich gleich nach dem Rückkehr " aus dem Dunklen" auf Arbeit fahren kann.
Ich habe den Kometen vermessen, m1=10m7, d=1'6, DC=6/. Er war ein einfaches Ziel im Zwölfzöller, und ich habe bei höherer Vergrößerung von 144x versucht, Einzelheiten zu sehen. Die waren relativ auffallend! Es lohnt sich, die anzusehen. Die zentrale Kondensation hat eine dreieckige Form, und diese Form drückt auch auf die Koma durch. Ich habe die Unregelmäßigkeiten markiert in der Zeichnung.
211007030029P_Ninja_144.jpg [ 6.52 KiB | 752 mal betrachtet ]
BeitragVerfasst: 13. Oktober 2021, 09:07:16 AM
29p_13_10_21_0219-0234_UT_Asi.jpg [ 404.89 KiB | 551 mal betrachtet ]
29p_13_10_21_0219-0234_UT.jpg [ 317.32 KiB | 551 mal betrachtet ]
Hallo Leute
Heute morgen um 2:19 hat es bei mir geklappt, den Kometen mit zwei Brennweiten
zu belichten.
Farbild Zwo Asi2600mc pro mit 305mm Newton bei 1186mm Brennweite.
S/W Bild Qhy268m-PH mit 340mm Hypergraph bei 1096mm Brennweite.
Jeweils 15x1min mit 2x2 Binning.
Finde die innere Struktur spannend.
Oliver
BeitragVerfasst: 17. Oktober 2021, 21:52:14 PM
Hallo Bevor das Mondlicht stört, konnte ich ihn noch in der Nacht vom 16. auf 17.10 erwischen. Das Bild ist mit 12"/4 und einer Nikon Z50mod 60 min belichtet Gruß Michael
29P20211017UT106sec8x120b.jpg [ 2.18 MiB | 216 mal betrachtet ]
29P20211016UT2343min60_3.jpg [ 1.56 MiB | 216 mal betrachtet ]
BeitragVerfasst: 21. Oktober 2021, 18:36:40 PM
Hallo Kometenfreunde,
hier zeige ich einen Animation aus zwei Nächten, die die Wanderung und auch die Größenänderung des Kometen zeigt.
Weitere Bilder unter:
http://www.balkonsternwarte.de/Kometen/29p_16_10_2021/
Oliver Schneider
29P_13-16_10_2021_qhy.gif [ 830.28 KiB | 59 mal betrachtet ]
