Aktuelle Zeit: 23. Januar 2026, 05:43:18 AM
Ein neues Thema erstellen  Auf das Thema antworten  [ 121 Beiträge ]  Gehe zu Seite 1 2 3 Nächste
 Betreff des Beitrags: C/2025 A6 (Lemmon)
BeitragVerfasst: 22. Februar 2025, 03:51:33 AM
MPEC 2025-D55 :
There were 2 reports of cometary activity.
The first report was by R. Weryk.
There were 2 reports of a coma and there was 1 report of a tail.
https://minorplanetcenter.net/mpec/K25/K25D55.html
COMET C/2025 A6 (Lemmon)
Helligkeit ca. 21 mag, H = 13.5 2.5n = 8
C2025A6.png [ 98.66 KiB | 339903 mal betrachtet ]
BeitragVerfasst: 23. Februar 2025, 02:19:50 AM
siehe auch CBET 5508:
http://www.cbat.eps.harvard.edu/iau/cbe ... 005508.txt
BeitragVerfasst: 23. Februar 2025, 11:22:41 AM
erreicht im Oktober 2025 gemäss Prognose 10m0, wird also durchaus interessant ......
BeitragVerfasst: 26. März 2025, 22:32:57 PM
Carl Hergenrother in his ALPO Comet News for March 2025 talks about C/2025 A6. He points out that this is a dynamically old comet with an orbit of 1300 years which may become a little brighter than the predicted magnitude 9 during the last week of October 2025. So, for the rest of the year unless we are blessed with a comet that has not been discovered yet, C/2025 A6 may be the brightest comet until the end of December when 24P may reach magnitude 8.
Cheers, Mike
:lol: Arizona
BeitragVerfasst: 19. August 2025, 12:03:33 PM
Hi Maik The comet is getting brighter, it is now 11m8 (Aug 19) Michael
2025A620250819UT200sec11x50RGB_2.jpg [ 2.43 MiB | 337381 mal betrachtet ]
BeitragVerfasst: 21. August 2025, 03:45:48 AM
CBET 5594 :
This comet (cf. CBET 5508) has had a notable outburst in brightness as
it appears now in the morning sky after being hidden by the sun's glare for
several months. H. Sato (Bunkyo-ku, Tokyo, Japan) obtained CCD exposures on
Aug. 11.49 UT with a 0.51-m f/6.8 astrograph located at the Utah Desert Remote
Observatory (near Beryl Junction, UT, USA) that show a strongly condensed coma
20" in diameter; the magnitude was measured as 14.5 within a circular aperture
of radius 11".5.
http://www.cbat.eps.harvard.edu/iau/cbe ... 005594.txt
BeitragVerfasst: 21. August 2025, 11:03:17 AM
Danke Michael für die Publikation. Die Helligkeitsentwicklung scheint noch viel günstiger zu sein, als im CBET angegeben. Der Komet ist aktuell tatsächlich 11mag hell und es scheint kein Ausbruch zu sein, sondern sich um eine dynamische Entwicklung eines langperiodischen Kometen zu handeln.
Für uns Fotografen positiv ist, dass er gasreich ist. Man kann davon ausgehen, dass der Komet Ende September einen Ionenschweif zeigt, der bis Ende Oktober auf >5 Grad anwachsen wird. Ich habe ihn mal verglichen mit 23P, der einen ähnlichen Perihelabstand zur Sonne hatte. Und der zeigte im Maximum 8 Grad Schweif und war definitiv lichtschwächer. Ja, es ist noch zu früh, sich auf eine spektakuläre Entwicklung zu freuen. Aber derzeit schaut die Sache sehr interessant aus. Gruß Michael
BeitragVerfasst: 21. August 2025, 13:44:17 PM
Bei COBS ist gerade eine Schätzung von J Gonzales aufgepoppt, mit 10.6 mag. Wenn man den Gonzales-Faktor anbringt, passt das gut zu Michaels Messung. :wink:
Ich selbst werde es morgen früh auch versuchen, leider steht der Komet noch ziemlich niedrig und ich bin nicht mehr, wie Anfang der Woche, unter Bortle 3 Himmel. Schaumer mal.
CS
Maik
BeitragVerfasst: 24. August 2025, 05:07:25 AM
Moin,
hat doch etwas gedauert... habe ihn gerade auf 10.9 geschätzt. Durchmesser 2.5' und DC 3-4.
18° über dem Morgenhorizont, da galt es die optimale Kombination zwischen Höhe und beginnender astronomischer Dämmerung zu finden.
Mal schauen, wie er sich noch entwickelt. Mit Glück ein netter Fernglaskomet Ende September (allerdings am Morgenhimmel)?
CS, Maik
BeitragVerfasst: 24. August 2025, 11:34:44 AM
Hallo Maik
Ich kam am 24.8. mit der Messung nur auf 11m4, allerdings nur die innere Koma, die äußere Koma ist auf den Grünaufnahmen bereits 7' groß - sollte der nicht sogar freisichtig werden?
lg Michael
2025A620250824ut215sec4x85filtergreen.png [ 2.91 MiB | 337080 mal betrachtet ]
BeitragVerfasst: 24. August 2025, 13:22:14 PM
Hallo Michael,
aufgrund der komischen Lichtkurve und der Frage Ausbruch oder nicht, bin ich vorsichtig. Aber ja, derzeit wäre ich bei 4 mag im Maximum, für mich bei 17° Höhe am Abendhimmel Ende Oktober.
Maik
BeitragVerfasst: 24. August 2025, 16:04:16 PM
Hallo Maik Die bisherige Lichtkurve kann man vergessen. Der Komet stand lange Zeit zu nahe bei der Sonne, die ersten Beobachtungen im August fanden bei tiefem Stand und Mondlicht statt.
Die CCD Helligkeiten, die nur den zentralen Bereich erfassen, sind für die Bemessung der Gesamthelligkeit wertlos. Und bei gasreicheren Kometen benötigt man ohnehin beste Transparenz, um die Helligkeit richtig zu bestimmen. Aber stimmt, ein Ausbruch ist trotzdem nicht auszuschließen. In einer Woche wissen wir mehr. Schön wäre, wenn er sich wie 153P entwickeln würde.
Im Anhang das Summenbild von nur 4x85 Sekunden mit Grünfilter
lg Michael
2025A620250825UT215sec4x85_.jpg [ 371.27 KiB | 337042 mal betrachtet ]
BeitragVerfasst: 24. August 2025, 22:08:54 PM
Hello Maik and Michael, collected some images at an altitude of 12 degrees in some hazy skies just before clouds moved in on the morning of 2025 August 23 UT. The astrometrica image does not show much of the coma, but using other software the coma visible was 2' wide, but very faint. The magnitude calculated using 30x10s images taken thru a green filter in an aperture diameter of 2' was G=11.3 which agrees fairly well with your observations.
2025A6_20250823_1040_molason.jpg [ 102.05 KiB | 336986 mal betrachtet ]
Cheers, Mike
:lol: Arizona
BeitragVerfasst: 25. August 2025, 16:46:05 PM
Hallo ,
nach 4,5 Monaten "Kometenabstinenz" konnte ich heute Morgen C/2025 A6 Lemmon sichten:
25.8.2025 02:30 UT : 11,0 mag; DC 3; ca 2´ . 125/750 mm Refr. V= 36x; SQL 21,01
Koma diffus, nur bei indirektem Sehen zu erkennen. Kometenfilter hilft!
VG, Otto
BeitragVerfasst: 26. August 2025, 09:37:19 AM
Hallo Otto, hallo alle,
ich konnte ihn ebenfalls heute morgen zum dritten Mal hintereinander beobachten. Ich schätzte ihn auf 10.8 mag, 3', DC3-4. Hatte ziemlich guten Himmel. Und ja, die Koma ist sehr undeutlich definiert.
Ich brauche jetzt Schlaf - dies ist die dritte Nacht mit nur 4-5 Stunden...
CS, Maik
BeitragVerfasst: 27. August 2025, 15:18:32 PM
Hallo Die Frage, ob das ein Ausbruch war, kann man langsam verneinen. Der Komet wird von Tag zu Tag heller. Heute früh waren es aus den Grünaufnahmen mit Astrometrica gemessen 10m6, die äußere Koma ist bereits 7,5' groß. Vom 19.8. bis 27.8 ist er damit ca 1mag heller geworden. Gruß Michael
2025A620250827green6x80b.png [ 2.95 MiB | 336262 mal betrachtet ]
BeitragVerfasst: 27. August 2025, 16:45:17 PM
hallo jungs, danke für die infos und die Bilder, ich kann da leider (noch) nichts beitragen, Komet morgens genau hinter unserem Haus ......
BeitragVerfasst: 28. August 2025, 02:44:00 AM
Blessed with an amazingly clear morning for monsoon season on 2025 August 27 UT. C/2025 A6 was magnitude G=10.8 as calculated from 30x10 second images taken thru a green filter in an aperture diameter of 3.5'. The measured visible coma observed with my small system was 3.5' with a very green coma. Roland, I have a family bulldozer, we could push your home a little one way or maybe it would be better for you to get a smaller portable system to use at the top of that hill behind your home ::)
2025A6_20250827_1138_molason.jpg [ 240.75 KiB | 336209 mal betrachtet ]
Cheers, Mike
:lol: Arizona
BeitragVerfasst: 28. August 2025, 13:12:24 PM
Hallo Heute wieder heller - 10m4 aus 4x80 mit Grünfilter und Astrometrica gemessen. Die äußere Koma ist nun 8' ein Schweif 7' in pa 290 ist angedeutet. Gruß Michael
20250&20250828sec4x80green.png [ 2.4 MiB | 336136 mal betrachtet ]
BeitragVerfasst: 30. August 2025, 23:31:57 PM
Had to wait for clouds to part so more into twilight than one would like on the morning of 2025 August 30. Comet C/2025 A6 was magnitude G=10.8 as calculated from 30x10s images taken thru a green filter in an aperture diameter of 3.5', same as back on August 27, so maybe a baseline is being established after the comets emergence from twilight resulting in a more expected magnitude curve which will get the comet to magnitude 4-5 in October as Seiichi Yoshida's curve suggest. Of course, it is a comet so who knows.
2025A6_20250830_1151_molason.jpg [ 202.02 KiB | 335567 mal betrachtet ]
Cheers, Mike
:lol: Arizona
BeitragVerfasst: 31. August 2025, 12:20:00 PM
hallo Forum,
heute Morgen gelang mir die erste Messung.
Die Nacht zuvor sah ich den Kometen, direkt vor der Haustür, im 10" Dobson nur blickweise durch Schleierbewölkung.
Der Komet löste sich zusehends aus den dichteren Horizontschichten.
Mein Lumicon Swanfilter sprach gut an !
Messung:
31.8.25 3:40 MESZ, Region SQL 20.3mag, in nur 16° Höhe über dem Horizont
21" Dobson, V 139x
10.8mag, DC 4, Durchm. 2.5`
In höherer Position ist der Komet sicherlich heller einzustufen.
BeitragVerfasst: 31. August 2025, 12:34:04 PM
Ich war heute morgen auch im Dunkeln. Endlich mal wieder ein Komet, der im Okular sofort zu sehen ist! Ich bestimmte mit dem 12-Zöller 11m3, mit 3,5 cm Öffnung und Airtools 10m8. Der Swan-Band-Filter wirkte gut, der Komet ist gasreich. Ich sah einen kurzen, spitzen Schweifansatz in PW=95°.
BeitragVerfasst: 31. August 2025, 13:16:39 PM
ich konnte den Kometen heute Morgen auch sichten:
31.08.2025 02:30 UT: 10,7 mag; DC 3 (4); ca 2´. 125/750 mm Refr. V = 36x; SQL 21,06
Otto
BeitragVerfasst: 31. August 2025, 13:28:16 PM
Moin!
Ich habe ihn heute morgen auf 10.0 mag geschätzt. Mir erschien er deutlich heller und auffälliger als vom 24.-26.8., er war nach dem Aufsuchen des Feldes direkt als helles Wattestückchen zu erkennen. Auch erschien er größer. Das hatte aber sicher auch mit der größeren Höhe zu tun, die nun schön über 20° ist und weiter ansteigt.
Er sieht auch gesund aus und - wer hätte das gedacht - scheint eventuell sogar ein freisichtiger Komet werden zu können!
CS Maik
BeitragVerfasst: 01. September 2025, 09:31:33 AM
Bei mir nur fotografisch. Mit 6” ist momentan nicht zu sehen.
Dateikommentar: MN 152 f/4.8, 15x30s Canon R
Screenshot 2025-09-01 at 06.18.24.jpeg [ 213.54 KiB | 335436 mal betrachtet ]
BeitragVerfasst: 01. September 2025, 12:15:37 PM
Ich hatte Montagfrüh die perfekten Bedingungen mit bester Transparenz und ohne Streulicht (Bortle 2). Fotografisch fand heute die Begegnung der Kometen C/2025 A6 und 414P statt. Nachdem ich nur mit dem 16 Zöller gearbeitet habe, ist die Helligkeitsschätzung von 10m6 der Wert nur für die helle innere Koma (gemessen aus 5x100 mit Grünfilter), Maiks Schätzung von 10m0 kommt der Sache nahe. Die Koma beträgt fotografisch 8' und der Ionenschweif ist 12' in PW 291 sichtbar. Auf den Blaufaufnahmen ist er deutlicher.
414 P hat offenbar in den vergangenen Tagen deutlich zugelegt und ist nun 15. Größenklasse hell.
2025A6innerekoma.jpg [ 527.17 KiB | 335408 mal betrachtet ]
BeitragVerfasst: 02. September 2025, 23:53:34 PM
On the morning of 2025 September 2 comet C/2025 A6 was magnitude G=10.4 as calculated from 30x10 second images taken thru a green filter in an aperture diameter of 4'. There is always a lot of speculation on what the size of a comets coma actually is, all that I and others can honestly due is report what we have observed and measured with our equipment, we can't be swayed by others to report something that we do not see. Anyone trying to determine the real magnitude of a comet must group together all magnitude measurements based on the comet coma widths reported, then must decide how much noise (stars, background, atmosphere, equipment, software used and other variables) has been introduced into those coma widths reported to try and calculated what a comets real magnitude actually is for any given time, good luck with that. There certainly is a point at which noise is actually contributing more than the outside comet coma magnitude contributions in all measurements no matter what software or methods are used. What most of us attempt to determine is a comet magnitude close to what others are observing give or take a 1/2 magnitude and using our own magnitude measurements calculated with our own equipment to determine if the comet is brightening or fading using our own magnitude calculated curve. The ultimate goal is that all of our curves agree how much a comet is brightening or fading, no one will ever calculate the real magnitude curve because there are just too many variables involved, the best we can do as a community is look at all the calculated curves, throw out the highs and lows, average the rest of them and that will probably come as close to reality as we can get for a comets actual magnitude curve as observed from the surface of the Earth.
2025A6_20250902_1156_molason.jpg [ 201.85 KiB | 335274 mal betrachtet ]
Cheers, Mike
:lol: Arizona
BeitragVerfasst: 04. September 2025, 18:51:24 PM
Ein lichtschwacher Ionenschweif ist nun (4.9.) fotografisch klar sichtbar, visuell war er im C14 bei 120x sehr einfach mit einer schön verdichteten 3-4' Koma, aber ohne Schweif.
Gruß Michael
2025A620250904UT230LRGBweb_3.jpg [ 2.44 MiB | 335176 mal betrachtet ]
BeitragVerfasst: 06. September 2025, 11:18:10 AM
Es geht munter weiter nach oben mit der Helligkeit. Heute früh war der Komet 9m5 hell, fotografisch waren Koma und Schweif 11' und 80' lang. Gruß Michael
2025A620250906UT230_4.jpg [ 1.39 MiB | 335027 mal betrachtet ]
BeitragVerfasst: 06. September 2025, 11:43:09 AM
Tolle Aufnahmen!
Ich komme gerade pünktlich zum Vollmond aus dem Urlaub zurück und werde heute Nacht auch mein Glück versuchen!
BeitragVerfasst: 06. September 2025, 12:33:41 PM
Hallo Michael,
die Satellitenspuren sind ja schon ein Graus... Ist der Komet derzeit in einer Gegend, wo die sich häufen? Bekommt man das noch vollkommen raus aus dem Bild?
Mich hat heute morgen der erste Nebel des Herbstes geschlagen. Mal sehen, wie hell er nach der Mondpause ist.
CS, Maik
BeitragVerfasst: 06. September 2025, 13:25:59 PM
Hallo Maik
Die Spuren lassen sich mit etwas Geduld entfernen. Ich hatte totales Glück, bis nach Mitternacht hat es geregnet, die Wolken zogen mit dem Monduntergang ab, sodass ich
noch eine schnelle Serie vom weiterhin lichtschwachen 414P auch machen konnte. Ich freu mich schon, was da auf uns zukommt.
lg Michael
2025A620250906LRGBweb_2.jpg [ 1.23 MiB | 335004 mal betrachtet ]
BeitragVerfasst: 07. September 2025, 12:12:02 PM
Hallo Michael, Hall alle,
Michael tolle Aufnahme!
C/2025 A6 entwickelt sich ja prima und wir dürfen einiges Erwarten! C/2025 A6 erinnert mich an C/2023 P1 Nishimura, der auch Ende August und Anfang September in den Morgenstunden 2023 zu sehen war.
Ich war gestern früh zeitgleich auch draußen, leider gelangte meine Beobachtung nicht ins Forum. Deshalb nochmals:
06.09.2025 , 2:45 UT : 9,9 mag; DC 4; Koma kreisrund 4,5´
125/750 mm Refr. V= 36x; SQL 21,00
Im 16x70 war der Komet blickweise zu sehen!
Allen viel Erfolg und Spaß.
LG, Otto
BeitragVerfasst: 07. September 2025, 18:20:32 PM
Bei mir hat es gestern nicht geklappt. Jede Menge Schleierwolken und Mond haben Beobachtungen unmöglich gemacht. Bin um 4 Uhr auch nochmal aufgestanden. Aber immernoch Wolken...
Schön, Michaels Aufnahmen zu sehen!
BeitragVerfasst: 18. September 2025, 05:21:18 AM
Moin!
Komme eben von der ersten Beobachtung des Kometen seit 14 Tagen rein (Mondpause). Schöne Konstellation mit der Mondsichel, die nicht mehr groß störte.
Vor 14 Tagen noch auf 9.8 mag geschätzt, habe ich ihn heute morgen mit den 10x50 auf 7.9 mag geschätzt (8.0 mag mit dem 15-cm Kometensucher). Schön kondensiert (DC 5) und eine schwache äußere Koma (5'). Der Komet wird spannend, wenn es so weiter geht.
CS, Maik
BeitragVerfasst: 19. September 2025, 13:02:05 PM
Ja, bereits 7mag heute früh mit fotografisch >2,5° Schweif, aber noch lichtschwach. Gruß Michael
2025A620250919ut230webcolor_3.jpg [ 665.21 KiB | 334160 mal betrachtet ]
BeitragVerfasst: 20. September 2025, 15:52:06 PM
sehr schöne Aufnahme, Michael ! mein Bild zur gleichen Zeit mit dem 16", so groß ist mein Feld natürlich nicht, und wäre wohl auch wenig sinnvoll bei den Bedingungen hier. (@mike: thanks for your offer with the bulldozer, the comet is now high enough to clear the roof of my house ....)
2025A6_20250919_0300_10B_2min_MG_L_R_b2.jpg [ 3.33 MiB | 334019 mal betrachtet ]
BeitragVerfasst: 21. September 2025, 10:19:54 AM
ich sah C/ 2025 A6 zuletzt am 19.9. und möchte die Beobachtung "nachreichen":
19.09.2025: 2:40 UT: 7,9 mag; DC 4-5; Koma 5,6 ´. 16x70 B
19.09.2025: 2:55 UT: 8,1 mag; DC 4 ; innere Koma 3,5´, ovale Form. 125/750 Refr. V= 36x
Der Komet entwickelt sich gut; wir dürfen gespannt sein was noch kommt.
cs
Otto
BeitragVerfasst: 21. September 2025, 12:11:04 PM
Hallo Otto
der wird ganz toll. Schon ein Monat vor dem Maximum ist er hoch aktiv. Das Bild vom 21.9.
Gruß Michael
2025A620250921UT240web.jpg [ 1.61 MiB | 333909 mal betrachtet ]
BeitragVerfasst: 27. September 2025, 09:56:37 AM
Es wird immer besser, Mosaik vom 27.,9 2.00 UT Gruß Michael
2025A520250927UT200min2x8mo_2.jpg [ 1.37 MiB | 333391 mal betrachtet ]
BeitragVerfasst: 27. September 2025, 12:40:03 PM
Eine Animation vom 27.9. mit 8" RASA 4 Aufnahmen je 2 Minuten Start 1.50 UT Ende 3.20 UT Gruß Michael
2025A620250927ut150min90b.gif [ 5.36 MiB | 333363 mal betrachtet ]
BeitragVerfasst: 30. September 2025, 09:11:37 AM
Liebe Kometenfreunde,
gestern morgen konnte ich mit dem Dwarf-Teleskop und einem SA-100-Gitter ein Spektrum des Kometen aufzeichnen. Belichtungszeit insgesamt 50 Minuten. Ihr wisst ja, das Lemmon gasreich ist, und so sind einige Swan-Banden zu sehen.
Lemmon.jpg [ 155.48 KiB | 333065 mal betrachtet ]
BeitragVerfasst: 30. September 2025, 19:31:39 PM
Sehr schön Uwe! Der kleine Zwerg taugt was.
Bei mir sind aktuell nur vereinzelte Lücken zu finden...
BeitragVerfasst: 01. Oktober 2025, 06:39:11 AM
C/2025 A6 entwickelt sich prächtig. Im 16x70 Bin. schon sehr auffällig, auch der Schweif war zu sehen!
1.10.2025: 3h30 UT: mv= 6,9 mag; DC 5; Koma 5´; Schweif 25´ in Pos. Winkel 298 °; 16x70 B.
Der Komet macht Spaß!
cs
Otto
BeitragVerfasst: 01. Oktober 2025, 13:55:11 PM
Ich kann Otto voll bestätigen. Auch ich schätzte ihn auf 6.9 mag bei 0.5° Schweif. Ich hoffe nur, der Nebel verschont mich morgen früh ebenso, so wie er es heute getan hat.
Vielleicht noch ganz interessant, dass ich das erste Mal mit einem Spektiv beobachtet habe. Mein Problem ist mein mittlerweile ziemlich großer Astigmatismus. Da ich nicht mit Brille beobachten kann/mag (und Kontaktlinsen auch nicht so das Wahre sind), sind Feldstecherbeobachtungen mittlerweile kein Spaß mehr. Kein Stern ist punktförmig... alles kleine Würmer. Da ich am Teleskop mittlerweile einen Astigmatismuskorrektor einsetze (Dioptrx) habe ich mich für ein Spektiv mit wechselbaren Okularen entschieden, welches mir ermöglicht, diese Okular und damit auch das Dioptrx einzusetzen. Mit 65 mm Objektivdurchmesser klein, kompakt und super transportabel mit leichtem Dreibein. So machen die mittelhellen Kometen wieder Spaß.
CS, Maik
BeitragVerfasst: 01. Oktober 2025, 20:18:29 PM
Hier ein erstes Spektrum von Etienne Bertrand (ALPY 600 Spaltspektrograph; 2025 Oct 01 03h27 UT):
https://lesia.obspm.fr/comets/lib/displ ... ?Num=30080
Die C2, C3, CN und NH2-Banden sind gut sichtbar. Ein schönes Spektrum eines sehr gasreichen Kometen....
Beste Grüsse
Matthias
BeitragVerfasst: 02. Oktober 2025, 08:14:17 AM
C/2025 A6 Lemmon heute Morgen bei klarem Himmel im Odenwald: SQL 21,03
2.10.2025: 2:30 UT; mv= 6,8 mag; DC 5; Koma 7´; Schweif 1,1 Grad ; Pos.Winkel 302 Grad ; 16x70 Bin.
2.10.2025: 3:30 UT; mv= 6,7 mag; DC 4-5; Koma 5,3´; Schweif 50´; Pos.Winkel 305 Grad; 125/750 Refr. V= 36x
Wird immer besser!
cs
Otto
BeitragVerfasst: 03. Oktober 2025, 09:15:13 AM
Hallo Heute bei feuchtkalten -4° aber sonst sehr dunklem Himmel beobachtet, der Schweif ist bereits >12° lang. Mosaik mit f-135/2.8 und Asi 294m Gruß Michael
2025A520251002UT310web_2.jpg [ 1.85 MiB | 332636 mal betrachtet ]
BeitragVerfasst: 03. Oktober 2025, 11:42:29 AM
Lieber Micha, es ist wirklich unglaublich, was du herauskitzelst. Ich bin begeistert.
 Betreff des Beitrags: Re: KOMET C/2025 A6 (Lemmon)
BeitragVerfasst: 03. Oktober 2025, 13:25:21 PM
Danke Uwe, es geht noch mehr. Wir hatten letzte Nacht zwar einen dunklen Himmel, bei minus 4 Grad und hoher Luftfeuchtigkeit zogen auch immer wieder Wolken durch.
Kommende Nacht soll es noch besser sein, so hoffe ich. Denn danach ist bei uns 1 Woche fast generell bewölktes Wetter angesagt. Gerald und ich waren gemeinsam, wir haben mit 2 Teleskopen und dem Tele gearbeitet. Auch die lange Brennweite gibt was her. Nur eine Vorschau, Animationen etc. folgen nächste Woche
2025A620251003UT258min12_2.jpg [ 1.9 MiB | 332582 mal betrachtet ]
