Aktuelle Zeit: 09. Februar 2026, 12:17:35 PM
 Betreff des Beitrags: New ground based BRITE campaign
BeitragVerfasst: 16. Dezember 2015, 16:18:46 PM
Hi all!
Here is a project Tony Moffat (Montréal) put together that might be of special interest for you. Currently BRITE is observing the famous O-type short-period binary UW CMa, in case you are interested. Updating of the wiki which gives what’s being and will be observed is in progress.
http://stsci.de/pdf/DRAFT_v4.pdf
Cheers, Thomas
 Betreff des Beitrags: Re: New ground based BRITE campaign
BeitragVerfasst: 16. Dezember 2015, 17:52:02 PM
Hi Thom:
Thanks for posting this! I already have SASER involved. And for 6 weeks I
had a visitor (Jamammad Rustamov) from Azarbaijan here to negotiate joint
observations using their 2m Zeiss telescope near Baku for spectroscopy.
Happy Christmas and Merry New Year!
Thon
-----Original Message-----
Sent: Wednesday, December 16, 2015 9:18 AM
To: fg-spek-admin@vdsastro.de
Subject: [fg spektroskopie] New ground based BRITE campaign
Link zum neuen Beitrag:
http://spektroskopieforum.vdsastro.de/v ... 387#p27395
Hi all!
in progress.
Cheers, Thomas
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Tony Moffat
BeitragVerfasst: 17. Dezember 2015, 13:16:43 PM
Hi Thomas!
I'm interested to work on this exciting project!
greetings
BeitragVerfasst: 17. Dezember 2015, 14:24:07 PM
Hi Thomas,
As you know, the southern hemisphere SASER group is also working on this
project and I am wondering if there is a way we can coordinate/communicate with
any northern hemisphere amateurs who plan to participate, especially if we
happen to pick some stars visible to both north and south. What do you
think?
Cheers, Bernard
SASER (Australia)
https://www.avast.com/?utm_medium=email ... mailclient
This email has been sent from a virus-free computer protected by Avast.
www.avast.com
Quicquid Nitet Notandum
BeitragVerfasst: 17. Dezember 2015, 15:33:17 PM
Hi,
the Position of the mentioned star is to near the horizont for me (my position is nearly N50°!) But what is with the other stars in the list attached?
I asked Prof. Moffat what format of spectra he whish........raw spectra or reduced one. But at time I have no answer......
Do you know this
cheers
BeitragVerfasst: 17. Dezember 2015, 16:32:07 PM
Hi all:
Sorry to be slow in answering, Berthold. The idea is for you to choose your
own targets based on a 2-step process:
1. From the list I circulated of windy massive (hot) stars, then among
those:
2. From the list of stars currently being observed by BRITE, as indicated on
the BRITE wiki: http://brite.craq-astro.ca/doku.php .
Currently BRITE is observing the CMaPup field (click on it and you'll see
the list of stars oops, sorry they're not up yet for some reason - I'll get
after this; but I do know that the O+O binary UW CMa is being observed).
The next field is CruCar (the targets are listed now). And so on...
Hope this helps. Now go for it! Your help in this will be much appreciated.
These are all very bright stars, so fairly easy to get frequent high-quality
spectra.
Best regards,
Tony
Sent: Thursday, December 17, 2015 8:33 AM
Subject: [fg spektroskopie] Re: New ground based BRITE campaign
http://spektroskopieforum.vdsastro.de/v ... 387#p27402
Hi,
attached?
Do you know this
cheers
Tony Moffat
BeitragVerfasst: 17. Dezember 2015, 16:57:47 PM
Hi Bernard!
Because the SASER team is hidden in the Web it would be best to announce the procedure how to become a list member so that everybody in the north is informed and can join SASER. The other possibility would be that SASER goes VdS forum. I am in both groups, so I do not mind. I presume the former is the better way to go because SASER is homogeneous, reliable and highly organized. In contrast to the south there is no real team organizer in the north.
Cheers, Thomas
BeitragVerfasst: 17. Dezember 2015, 22:12:02 PM
Hi Thomas,
As you well know SASER is just a small southern email ring designed to
allow campaign specific coordination between amateurs and pros and not a general
discussion forum. As SASER membership is limited to amateurs willing and able to
contribute spectra I think the best way to collaborate with a northern BRITE
contributor is for that person to contact me via this forum and I can then add
them to the SASER list.
Cheers,
Bernard
www.avast.com
BeitragVerfasst: 17. Dezember 2015, 22:15:35 PM
That is exactly what I mean, Bernard! SASER is exclusively for the observers and should continue like that. Cheers, Thomas
BeitragVerfasst: 18. Dezember 2015, 03:50:03 AM
Hi again:
The currently observed field with BRITE, CMa/Pup, is now on the wiki so you
can choose your stars as of point 2. below.
Cheers, Tony
Sent: Thursday, December 17, 2015 9:31 AM
To: Berthold Stober
Subject: Re: [fg spektroskopie] Re: New ground based BRITE campaign
Hi all:
those:
spectra.
Best regards,
Tony
Hi,
attached?
Do you know this
cheers
Tony Moffat
BeitragVerfasst: 28. Januar 2016, 17:05:13 PM
im Rahmen der Kampagne untersuche ich auch eps persei. Ich will hier nicht in Einzelheiten gehen, aber es ist schon beeindruckend, wie sich in sehr kurzer Zeit Linienprofilveränderungen zeigen, z.B. schon nach 15 Minuten im Bereich der Linie 6678 oder auch an den SiIII Linien........das S/N liegt nach 3x300 sec über 300.....naja, gut der Stern ist recht hell und steht hoch am Firmament.
Dateikommentar: auch die SiIII Linien zeigen diese Pulsationsprofile
eps_persei160119_4531_4598.png [ 19.92 KiB | 2707 mal betrachtet ]
Dateikommentar: schon nach 15 Minuten sieht man deutliche Profilveränderungen bei 6678
e_persei_90sec_ov_he160121.png [ 19.51 KiB | 2707 mal betrachtet ]
BeitragVerfasst: 28. Januar 2016, 17:16:02 PM
Hello Berthold:
Which campaign are you referring to? BRITE is not observing the Perseus
filed now; it was already done in 2014/15. eps Per will, however, be
observed again by BRITE starting next September. The PI for this star is
Gerald Handler, now in Warsaw.
Beste Gruesse,
Tony
Sent: Thursday, January 28, 2016 10:05 AM
http://spektroskopieforum.vdsastro.de/v ... 387#p27469
Tony Moffat
BeitragVerfasst: 02. Februar 2016, 12:09:21 PM
Hi Tony,
perhaps I confused something. Prof. Gerald Handler is now inetrested at this time on those spectra of this star. He asked me to create some spectra.
herzlicher Gruss
