| Calibration on the ESPRESSO spectrograph https://forum.vdsastro.de/viewtopic.php?t=5024 |
Seite 1 von 1 |
| Autor: | Filipe Dias [ 06. Dezember 2017, 14:04:57 PM ] |
| Betreff des Beitrags: | Calibration on the ESPRESSO spectrograph |
Hi all, have you seen the news? The ESPRESSO spectrograph at ESO has made its firstlight on a star. https://www.eso.org/public/unitedkingdom/news/eso1739/ The echelle spectrum looks nice How to make such well-spaced calibration source? is it at a constant in CCD-space or is it constante distance in wavelength? What do you think? |
| Autor: | Thomas Eversberg [ 06. Dezember 2017, 14:24:06 PM ] |
| Betreff des Beitrags: | Re: Calibration on the ESPRESSO spectrograph |
Hi Fil, they use a Laser Frequency Comb (see chapter 12.9.2 on page 461 in "Spectroscopic Instrumentation"). It is a constant distance in wavelength. You can use it if you have about 100.000 Euros. Cheers, Thomas |
| Autor: | Otmar Stahl [ 06. Dezember 2017, 14:39:29 PM ] |
Hi, Zitat: How to make such well-spaced calibration source? is it at a constant in CCD-space or is it constante distance in wavelength? https://en.wikipedia.org/wiki/Frequency_comb As noted by Thomas, this is an expensive calibration source. Another option for a calibration source with equidistant lines is a Fabry-Perot https://en.wikipedia.org/wiki/Fabry%E2% ... rferometer This is a cheaper (but not cheap..) solution, but needs careful stabilisation. https://arxiv.org/abs/1404.0004 Best regards, Otmar |
| Autor: | Olivier GARDE [ 06. Dezember 2017, 14:57:12 PM ] |
We were fortunate in 2016 to visit the assembly hall of Espresso at the Geneva Observatory with its designer Francesco Pepe. In addition to laser calibration unit, for the flats they use a 10 000 K light source. LDLS : Laser Driven Light Source. The spectro is also regulated in temperature at 1/100 degrees Celsius in a double enclosure. ![]()
| Autor: | Filipe Dias [ 07. Dezember 2017, 02:34:22 AM ] |
Zitat: The frequency comb is equidistant in frequency
The spectrum looks so nice! I asked bout the frequency comb "spacing" because there appears to be little change in dispersion throughout the complete spectrum! It seams only 25% greater in red than blue... is this natural in an Echelle, possibly because of different orders instead of only a singe order in traditional spectrographs? Of course, I do not know how they got a color pitcure out of the spectrograph (color camera or post processing to simulate wavelength?) so it is hard to see what wavelengths are shown.. but I am curious to find out what the distance between the dots is in wavelength It should be forbidden to show such nice output images to people who have not yet completed building their first [echelle] spectroscope! |
| Autor: | Olivier GARDE [ 07. Dezember 2017, 09:15:52 AM ] |
It's not a color CCD, (Color CCD is not the good solution for spectroscopy because of the Bayer matrice and the poor efficiency of a color CCD) but 2 larges monochrome CCD (90x90mm) one for the red part of the spectrum, the second for the blue part. In fact the color spectrum is process like a color picture by mixing the 2 composants R and B together, so it's not an RGB image, but an RB image.See the optical design below :
| Autor: | Christian Netzel [ 07. Dezember 2017, 09:20:38 AM ] |
Hi, where is the problem? You need only 1975 C14 to feed this nice echelle. Christian |
| Autor: | Andrew Smith [ 07. Dezember 2017, 11:08:52 AM ] |
Zitat: Hi,
Maybe a C8 would do to keep the cost down.where is the problem? You need only 1975 C14 to feed this nice echelle. Christian Regards Andrew |
| Autor: | Thomas Eversberg [ 07. Dezember 2017, 12:28:31 PM ] |
Zitat: You need only 1975 C14 to feed this nice echelle.
Well, not really... F/2.5 focus at seeing always less than 0.5 arcsec |
| Autor: | Daniel Sablowski [ 07. Dezember 2017, 18:27:21 PM ] | ||
| Betreff des Beitrags: | Re: Calibration on the ESPRESSO spectrograph | ||
Hi see, e.g., the shift-detection with a Fabry-Perot-Etalon on PEPSI: https://arxiv.org/pdf/1505.06492.pdf It is very important to stabilize such a device, since peak position and separation depends on the distance between the two mirrors. You can simulate a Farby-Perot output with SILENT. In my echelle FLISES I glued a second fibre at the entrance directly beside the science fibre. This fibre provides a simultaneous calibration signal (Th/Ar at the moment). I attached a pic of a test with arcturus and the Th/Ar signal. Here you would also need to have a blue filter to suppress the strong Ar lines (as done for flatfielding to pronounce the blue orders of the halogen signal). The good thing: Th/Ar lamp is stable! The bad thing: Lesser lines and blended, more difficult to detect small shifts. best, Daniel
