Aktuelle Zeit: 15. Januar 2026, 07:26:16 AM
 Betreff des Beitrags: Notation help
BeitragVerfasst: 21. Juli 2018, 11:59:00 AM
H ave been trying to understand spectroscopic notation and have made some progress. However, when looking at the Spectral atlas of Arcturus I have come across notation I can't track down.
Examples are Q124*** , P240** and R132
I would be please to have any explanation or pointers to where to look these up as Google did not seem to help.
Thanks Andrew
PS I have spotted they are related to molecular lines but if anyone has a good reference that would be helpful.
 Betreff des Beitrags: Re: Notation help
BeitragVerfasst: 21. Juli 2018, 14:33:46 PM
Hi Andrew,
may be
C. R. Khitchin, Optical Astronomical Spectroscopy
will help. There is a section and list of other publications about molecular spectra. Google may help you under the keyword IR spectroscopy.
BeitragVerfasst: 22. Juli 2018, 09:47:07 AM
Hi Andrew,
I think it's about molecular spectroscopy. The designations are typical for the P, Q and R- branches of a vibrational band. Take a look at Wikipedia under "Rotational-vibration Spectroscopy":
"...In the simplest cases the part of the infrared spectrum involving vibrational transitions with the same rotational quantum number (ΔJ = 0) in ground and excited states is called the Q-branch. On the high frequency side of the Q-branch the energy of rotational transitions is added to the energy of the vibrational transition. This is known as the R-branch of the spectrum for ΔJ = +1. The P-branch for ΔJ = −1 lies on the low wavenumber side of the Q branch. The appearance of the R-branch is very similar to the appearance of the pure rotation spectrum, and the P-branch appears as a nearly mirror image of the R-branch"
The number behind the letter P,Q,R indicates the associated rotational transition.
Kind regards
Klaus
BeitragVerfasst: 22. Juli 2018, 17:16:39 PM
Thanks both for your replies. I understand now and know where to look if I need more detail.
Regards Andrew
