Die CBET-Meldung zu P/2018 P1 ausnahmsweise als voller Text:
Electronic Telegram No. 4538
Central Bureau for Astronomical Telegrams
Mailing address: Hoffman Lab 209; Harvard University;
20 Oxford St.; Cambridge, MA 02138; U.S.A.
e-mail: cbatiau@eps.harvard.edu (alternate cbat@iau.org)
URL http://www.cbat.eps.harvard.edu/index.html
Prepared using the Tamkin Foundation Computer Network
COMET P/2018 P1 = P/2010 A1 (HILL)
E. Schwab, Egelsbach, Germany, reports his recovery of comet P/2010 A1
(cf. IAUCs 9104, 9107) on CCD images obtained by P. Ruiz on Aug. 10.2 UT with
a 1.0-m f/4.4 reflector at the European Space Agency's Optical Ground Station,
Tenerife, Spain; the comet shows a faint tail extending about 15" in p.a.
260 degrees. M. Micheli reported confirming CCD astrometry from observations
obtained on Aug. 12.3 by F. Monteiro and five other observers with a 1.0-m
f/7 reflector at the Observatorio Astronomico do Sertao de Itaparica at
Nova Itacuruba, Brazil.
2018 UT R.A. (2000) Decl. Mag. Observer
Aug. 10.18050 3 57 28.00 +17 38 53.3 19.0 Ruiz
10.18502 3 57 28.54 +17 38 56.0 19.1 "
10.18804 3 57 28.90 +17 38 57.6 19.0 "
12.29450 4 01 41.51 +17 58 57.9 20.7 Monteiro
12.29700 4 01 41.82 +17 58 59.3 19.6 "
12.29947 4 01 42.11 +17 59 00.7 20.6 "
The indicated correction to the prediction by B. G. Marsden on MPC 94681
is Delta(T) = +0.39 day. The following linked orbital elements by G. V.
Williams (from 150 observations spanning 2010 Jan. 6-2018 Aug. 12; mean
residual 0".6) and an ephemeris appear on MPEC 2018-P80.
Epoch = 2018 Oct. 9.0 TT
T = 2018 Oct. 15.15907 TT Peri. = 13.28370
e = 0.5542467 Node = 47.32113 2000.0
q = 1.9571781 AU Incl. = 10.30827
a = 4.3907202 AU n = 0.10712737 P = 9.20 years
NOTE: These 'Central Bureau Electronic Telegrams' are sometimes
superseded by text appearing later in the printed IAU Circulars.
(C) Copyright 2018 CBAT
2018 August 13 (CBET 4538) Daniel W. E. Green
