Aktuelle Zeit: 07. Februar 2026, 07:31:37 AM
BeitragVerfasst: 04. Juni 2019, 07:32:26 AM
( 22 mag im Juni 2009)
Erwin Schwab aus unserer Fachgruppe hat diesen Kometen wiederentdeckt. Herzlichen Glückwunsch! Der Originaltext der CBET-Meldung:
COMET P/2019 K3 = P/2007 R1 (LARSON)
    E. Schwab, Egelsbach, Germany, reports his recovery of comet P/2007 R1
(cf. IAUC 8867) on CCD images taken remotely with the 0.8-m f/3 Schmidt
reflector at Calar Alto, Spain, on two nights (May 29 and June 3 UT); no coma
and no tail was visible on frames with a total exposure time of 600 s.  G. V.
Williams, Minor Planet Center, reports his recovery of this comet also in
incidental astrometry submitted by the Pan-STARRS1 survey (apparently
asteroidal images obtained with the 1.8-m Ritchey-Chretien reflector at
Haleakala on May 31).  The astrometry is tabulated below.
    2019 UT             R.A. (2000) Decl.       Mag.   Observer
    May  29.08794   16 42 15.85   -13 26 23.9   21.9   Schwab
         29.10684   16 42 15.21   -13 26 22.0   21.7     "
         29.11628   16 42 14.94   -13 26 22.4   22.1     "
         31.45154   16 41 08.96   -13 23 24.6   22.0   PanSTARRS1
         31.46447   16 41 08.59   -13 23 23.4   22.0     "
         31.49031   16 41 07.86   -13 23 21.6   21.9     "
    June  3.00463   16 39 56.43   -13 20 20.5   22.1   Schwab
          3.01404   16 39 56.12   -13 20 19.1   21.6     "
          3.02346   16 39 55.88   -13 20 18.5   21.3     "
          3.03287   16 39 55.56   -13 20 17.7   22.1     "
The indicated correction to the prediction by Williams on MPC 75514 is
Delta(T) = -0.08 day.  The following linked orbital elements by Williams
(from 226 observations spanning 2007 Sept. 4-2019 June 3; mean residual 0".6)
and an ephemeris appear on MPEC 2019-L42.
                   Epoch = 2022 Mar. 2.0 TT
    T = 2022 Feb. 17.41718 TT        Peri. = 170.98593
    e = 0.3169734                    Node  = 173.74093 2000.0
    q = 4.4197574 AU                 Incl. =   8.31059
      a =  6.4708426 AU   n = 0.05987738   P =  16.46 years
NOTE: These 'Central Bureau Electronic Telegrams' are sometimes
     superseded by text appearing later in the printed IAU Circulars.
                        (C) Copyright 2019 CBAT
2019 June 4                      (CBET 4635)              Daniel W. E. Green
BeitragVerfasst: 29. September 2021, 09:02:53 AM
Atel 14940
https://www.astronomerstelegram.org/?read=14940
berichtet von einem Ausbruch des Kometen aum ein Größenklasse auf 17m8 (5"-Apertur)
