Aktuelle Zeit: 28. Juli 2021, 02:52:44 AM
 Betreff des Beitrags: 15P/Finlay
BeitragVerfasst: 12. Mai 2021, 14:02:12 PM
Alan Hale berichtet auf der Mailing-Liste, dass der Komet recht hell sei (13,3 mag, visuell). Richard Miles erinnert an die Ausbrüche 2014 - und damit indirekt auch darn, dass es lohnt, ihn zu beobachten. David Seargen rät, auf Fragmente zu achten.
Momentan noch nichts für den deutschen Sprachraum (im Wassermann).
 Betreff des Beitrags: Re: 15P/Finlay
BeitragVerfasst: 21. Mai 2021, 13:47:59 PM
Hello All,
Some images of Comet 15P/Finlay collected 20 May 2021. Unfortunately some high clouds also were collected in the images. The images showed the comet at about magnitude 15 with a 44" coma and no tail evident, not sure how much the high clouds interfered with this data and the start of twilight.
15P_20210520_1102_molason.jpg [ 287.68 KiB | 454 mal betrachtet ]
Cheers, Mike
:lol: Arizona
BeitragVerfasst: 27. Mai 2021, 11:42:01 AM
Hello All,
Managed to get some images of Comet 15P/Finlay before the start of twilight on 23 May 2021. The comet is magnitude 14.9 with a 44" coma and what appears to be a very faint fan shaped area about 1' long from PA 45-170 degrees that may hint of a tail behind the comet as seen from my little telescope. The comet does not appear as bright as some have reported, but others have much better equipment than mine to make such measurements.
15P_20210523_1039_molason.jpg [ 253.6 KiB | 314 mal betrachtet ]
Cheers, Mike
:lol: Arizona
