Aktuelle Zeit: 15. Januar 2026, 22:08:02 PM
BeitragVerfasst: 12. März 2011, 13:44:35 PM
Hi,
In a Littrow-design spectrograph, what would be the dominant aspects that could limit the size of the image (spectrum) formed on the sensor? (what would limit the choice for sensor size?)
What would limit a Lhires to 7~8 mm of spectrum ? (I think that is the official number)
Fil.
BeitragVerfasst: 12. März 2011, 18:58:07 PM
Hi Filipe
It depends on the aberrations of your system (not only on the camera lens). The dominating factor is the image curvature. Also the chromatic focal shift is important. Both should be as small as possible over the image. The chromatic focal shift is a general problem for a spectrograph which cover the whole visible. Also by rotating the grating. So, image curvature is the determining aberration, if there are no off-axis aberrations. If the systems works under strong off-axis, astigmatism will be important. But such a bad system would only work well if you do not need to rotate the grating. But this depends also on the spectrograph mounting. In the case of a CT spectrograph the astigmatism is constant over the whole spectra and spherical aberration determines the R.
If there is a system under development all aberrations are important in general and for the sice of the ccd image curvature is most important.
I hope this was a slightly helpful
BeitragVerfasst: 13. März 2011, 14:51:15 PM
Hi Daniel,
Is the image curvature you mention from the optics inside the spectrograph? It could possibly be caused or made worse because of the light not going through the objective/collimator parallel to the optical axis..
Does it make sense that by replacing a small doublet (working as objective and collimator) by a larger optical assembly (possibly a photographic objective) of the same focal distance that the image could be better corrected?
And what about distance of the grating to the objective/collimator? I imagine that the closest they are, light goes less "off-axis" from the optical axis, however it goes in at a slightly greater angle..
Would problems increase if the focal length of the collimator/objective would be longer or shorter?
Fil.
BeitragVerfasst: 13. März 2011, 20:39:01 PM
Hi Filipe
Hi Daniel,
Yes.
I think, I do not realy understand this.
Yes! Optical systems have some importante parameters. One of thies is refractivity. In general aberrations will be reduced, if the refractivity of the system is spread to many surfaces. So, an objective with many lenses is better corrected. It is always a quastion how good a system must be corrected. In the case of a littrow as an astronomical spectrograph a doublet is good enough for the most applications.
Should be small as possible. In the case of a littrow not so good realized.
The aberrations increas in general if the focal lenght decreases, specially spherical aberration. But focal length and aberrations must always be treated in context with the diameter of the optic. The F-number is more meaningful. Small F numbers, fast optics are in general worse corrected.
image_curvature.JPG [ 14.08 KiB | 5502 mal betrachtet ]
BeitragVerfasst: 14. März 2011, 01:26:02 AM
Thank you Daniel!
Very informative.
Fil.
BeitragVerfasst: 14. März 2011, 19:47:06 PM
No problem Filipe
