Aktuelle Zeit: 17. Januar 2026, 04:37:43 AM
BeitragVerfasst: 01. Oktober 2025, 00:28:07 AM
MPEC 2025-S299 :
https://minorplanetcenter.net/mpec/K25/K25ST9.html
COMET P/2005 T5 = 2025 S1 (Broughton)
Helligkeit ca. 18 mag, H = 11.0 2.5n = 10
P2005T5.jpg [ 232.49 KiB | 6697 mal betrachtet ]
BeitragVerfasst: 01. Oktober 2025, 22:54:41 PM
siehe auch CBET 5616 :
G. J. Leonard recovered comet P/2005 T5 (cf. IAUC 8621) accidentally on
CCD images obtained by on Sept. 24 UT with the Mount Lemmon Survey 1.5-m
reflector. He reported it to the Minor Planet Center as a recovery, and D.
Rankin then acquired follow-up CCD observations on the following night with
the 1-m Steward Observatory reflector at Mt. Lemmon, which showed a condensed
coma about 4" across with a straight tail about 6" long in p.a. about 260
degrees.
http://www.cbat.eps.harvard.edu/iau/cbe ... 005616.txt
